1000 watt amp POWER SOURCE !@
I have a 1000 watt amp just runing off my stock battery what else should i buy to help this amp be able to push its maxium power out ? I am pushing 2 kicker comp vr 12's. Aiwa cd player.
Re: 1000 watt amp POWER SOURCE !@ (lilredridinghood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredridinghood »</TD></TR><TR><TD CLASS="quote">capacitors </TD></TR></TABLE>
Wrong answer. Is your amp supposed to put out 1000w max or continuous? Do you know its max current draw? What makes you think that you're not getting enough power?
Re: 1000 watt amp POWER SOURCE !@ (bla1ne)
find out if the amp is 1000w RMS or 1000 w peak if its peak you shouldnt need anything if its RMS get a cap. 1 farad at least maybe 1.5 farad.
find out if the amp is 1000w RMS or 1000 w peak if its peak you shouldnt need anything if its RMS get a cap. 1 farad at least maybe 1.5 farad. my guess is it is 1000w peak but i could be wrong
Re: 1000 watt amp POWER SOURCE !@ (js96ek)
If your lights dim a cap may make it worse. It'd be significantly cheaper to replace your ground wires, which could also solve your problem.
Sinner
Audio / Security / Video
02-14-2006 07:27 PM
