1" teg master cylinder for brake swap on 95 civic
ok, i cant remember what years its off of, but the 1" teg master cylinder that DOES NOT require you to rebend the line.. anyone know what one is it. i read it on a post her once before and i dont know where to find it. the last time i swapped the cylinder i had to change the flare nut. i am looking for the cylinder where you can use both 8mm (i think) flare nuts that come on the 95 civic
Re: 1" teg master cylinder for brake swap on 95 civic (gsxr1k05)
not quite sure ur question but the 1 inch has two different nuts on it. one is a bit beefyer. also make sure u get the brake booster too. i have a 98 civic and i needed to change the booster and i swapped my friends 92 civic and he needed a new booster too because the alignment was different for the master cylinder. last thing is get the proportioning valve.
i know you get the booster and master cylinder together. i have done this swap before, but i read on here that there is a master clyinder that doesnt have the different size nuts
zuptidi
10-30-2014 04:18 PM
