0rule of thumb
TSPeed Factory
rule of thumb
I was reading and look at some interesting facts i found:
here are some good information i gathered from various magazines on making power and dropping weight in your car...this is only a rule of thumb, and is to not be mistaken for exact numbers, because all cars are different
1. A 10% drop in the temperature going into your motor will result in a 1% horsepower gain
2. For every 1000 lb. drop in a car will result in 1 second off your quarter mile (I don't know if this is true in imports, because i got this info. out of a hot rod magazine)
3. For every 10 lb. drop in a car will result in a 1 horsepower gain (This doesn't exactly mean 1 horsepower gain to your motor but you will feel a 1 horsepower gain on your 1320 dash, or 10 horsepower faster with 100 lb. drop)
[Modified by AzntaggeR, 8:34 PM 1/27/2003]
Re: rule of thumb (AzntaggeR)
1. I can believe this.
2. I think it's less than 1000lbs in my opinion...something closer to 600 give or take.
3. I think this is just restating 2. since motors don't gain hp when the car drops weight it's just that they pull that weight more efficiently.
Re: rule of thumb (Jay-C)
thanks for sharing the info....
Re: rule of thumb (ProEater)
will 100lbs is 1/10 of a sec so that kinda makes since...
10 lbs = 1 hp well just figure this and you'll be doing good.
weight / hp = how many pounds you are pulling per hp (did i say that right) so basically you lower that and you will have a better power to weight ratio i think a civic is around 20lbs or per hp and a 1999 mustang saleen is like 6 per hp...atleast that is what i got from a site. hope that helps.
DEF
DEF
Re: rule of thumb (deftones0817)
DEF
DEF
Re: rule of thumb (fire7882)
a 99 mustang saleen the super charger one not the na one makes 490 hp. So roughly that is correct...maybe be off by a pound. That **** is hella fast my friend has one and the specs i looked up say 490.
DEF
DEF
TSPeed Factory
yea..that's why it's critical that you watch what you put in your car if your concerned with keeping the weight of ur car to a minimal
Re: rule of thumb (purek9hybrid)
A rod unbalanced 4oz puts force of over 400lbs on the crank at 7500 rpm.
1 lbs of unsprung weight = 10 lbs off sprung weight. (1lbs lighter flywheel is like takin 10 lbs off your car.)
Re: rule of thumb (redcxhatch)
Re: rule of thumb (EKology)
Imagine if all 4 rods were unbalanced 4 oz.
Major problem with V8's, you can gain like 30-40hp buy balancing bottom end. I wish i could get the same results from my 1.5!
all_motor_mike
05-28-2006 12:45 PM
Blitzkrieg
01-04-2004 04:30 PM
