02 sensor questions
02 sensor questions
I have a 96 HX and I am going to put an EX head and ECU on it and I was wondering what I will have to change as far as 02 sensors or will the ECU plug in. Also I was told that I need a wide band 02 censor for a A/F ratio gauge and I believe that the HX has the wide-band 5 wire on it already. Please correct me if I am wrong. Also if you know of anything else that I have to change to get that ECU to work please let me know. I am putting a P2P in it so everyone said that it should plug in but I was just wondering about the O2 problem. Thanks Alot
James
James
Re: 02 sensor questions (civicnar)
Since you are changing over to the P2P, it will be looking for a 4 wire 02 sensor. I would say just replace the existing one you have and repin the wires to read as a 4 wire 02 sensor on the harness.
As far as the A/F guage, without a wideband sensor they are little more than a light show. I don't know 100% if they HX comes with a wideband 02 sensor or how you would hook that up to an A/F guage. If you do end up using it though, I'd just tap another hole in your exhaust or exhaust manifold before the cat.
Re: (civicnar)
there's a thread on here somewhere about how to repin. I'll look for it. You need to find the pinouts for you ECU now and for the P2P and rearrange as necessary.
EDIT: Imagine that, I had posted it in the FAQ thread.
https://honda-tech.com/zerothread?id=587460
JKim0901
02-04-2002 09:44 PM
