02 EP SiR steering wheel on 2000 EK SiR
Old 04-25-2005, 07:24 PM
B-lue16A_EK's Avatar
Default 02 EP SiR steering wheel on 2000 EK SiR
Hi
has anyone tried to put on the new 3-spoke 02 EP SiR steering wheel (with air bag) on 2000 EK SiR?
Does it need any modification and will the air bag and cruise control work as normal?
thanks
Old 04-25-2005, 07:36 PM
CIVIC dude's Avatar
Default Re: 02 EP SiR steering wheel on 2000 EK SiR (B-lue16A_EK)
i tried it and the airbag connectors are different. so it wont be plug and play.
If you like the look, you can get a JDM RSX steering wheel and the S2k steering wheel also work in EK's.
I have the JDM rsx R on my EM1
Old 04-25-2005, 09:42 PM
Default Re: 02 EP SiR steering wheel on 2000 EK SiR (CIVIC dude)
cool
it looks real nice
So it just install directly except the mod on the wiring of the air bag?
thanks
Old 04-26-2005, 03:02 AM
CIVIC dude's Avatar
re read my post
USDM RSX wheel will NOT work, it has different airbag connectors.
The JDM RSX wheel will work as it has the SAME connectors.
Old 04-26-2005, 03:12 AM
137's Avatar
And you didnt do any research at all to see if you could just purchase the correct connectors from honda or use your old airbag connectors and just replug the wires into the correct spots?
Seems doable to me. Then again I've never taken my steering wheel off.
Old 04-26-2005, 03:24 AM
Lover
Audi RS4's Avatar
how much do they run?
Old 04-26-2005, 11:34 AM
CIVIC dude's Avatar
Default Re: 02 EP SiR steering wheel on 2000 EK SiR (137)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">And you didnt do any research at all to see if you could just purchase the correct connectors from honda or use your old airbag connectors and just replug the wires into the correct spots?
Seems doable to me. Then again I've never taken my steering wheel off. </TD></TR></TABLE>
Of course i did research. Honda doesnt sell just the airbag plugs as you arent supposed to be messing around with the airbag.
also the main problem is the USDM EP steering wheel is a dual stage airbag. The EK and the JDM rsx wheel are single stage.
That is another reason why i wouldnt mess with it.
Check ebay they run for appx $400US
Old 04-26-2005, 11:47 PM
by the way are those cruise control buttons (accel, decel and cancel) work as normal ?
Old 04-27-2005, 11:38 AM
CIVIC dude's Avatar
they function as stock, but a little mod is neccessary.
i figured it out
grandam
07-07-2013 05:09 PM
95boostedh22
09-09-2008 07:28 PM
GserpleaSR
11-21-2006 09:51 PM
LagunaSecaEG
08-21-2006 03:20 AM
StreetFighter
10-08-2001 10:19 AM
Quick Reply: 02 EP SiR steering wheel on 2000 EK SiR
