00 civic si with a turbo gsr swap - turns over but won't start
i put a turbo gsr swap in my 00 civic si and converted it to obd1 with a chipped p28 ecu and a conversion harness. i have fuel and spark but for some reason it won't start. just keeps cranking over and over. if i pull the plugs and set them on top i get even sequential fireballs. anyone have any idea's.
Resident Gearhead
Re: 00 civic si with a turbo gsr swap - turns over but won't start
Could be, I was going to come in here and mention that.
This little guy is supposed to help B-series belts from jumping teeth:
http://theoldone.com/components/cam_..._tensioner.htm
Originally Posted by ENDYN
We designed the belt tensioner to eliminate the timing belt whip associated with tall-deck engine combinations as well as those running camshafts with high-rate opening and closing ramps. When contacting the outside of the timing belt on the engine's exhaust-side, the belt deflection both between and after the timing gears is eliminated, dramatically reducing the chances of belt slippage. This device also allows one to set cam belt tension using the method (suggested by Honda) rather than the "screw-driver" technique that tightens the belt to the extent that there's no oil clearance, which typically ends up galling the front cam bearing journals in the head .
Construction is CNC-machined billet aluminum with stainless steel washers and fasteners. The tensioner roller is black-oxide coated steel with premium ball bearing rated to 40,000 RPM.
Construction is CNC-machined billet aluminum with stainless steel washers and fasteners. The tensioner position is adjustable by loosening two bolts. The design of the tensioner also permits use with minimal belt shroud trimming.
This kit is intended for use with B series VTEC head applications. It will not work with non-VTEC heads.
Price is $134.50 each
How long did you do the firing of the plugs out of the cylinder? If you did it for too long, you could've burned up your coil. Not alluding it to your no start problem but a problem you can encounter down the road because of it.
timing was my first idea, ripped the covers off and timing is spot on. and the spark plug idea, i have a msd ignition and coil on it and just put new NGK plugs in. i haven't done the spark plug idea for long, just once to make sure the firing order and injectors were all working correctly. i'm so confused as to why it won't start
found out what it was. if anyone has this problem and has and aftermarket coil it might have gone bad.... replaced the coil and it fired right up. had spark just apparently wasn't enough
d4ng3rb0y
15
11-24-2009 08:15 AM
Jack Shephard
12
02-13-2009 06:27 PM
90CIVICSI
07-07-2002 08:49 PM
