'00 civic si lip on eg??
i was wanting some help if you guys can help me...my younger brother wants to get a 2k si front lip off a civic and was wondering if it would bolt on to a 92 civic hatch dx..?? would it jus be bolt on or you have to modify the lip to make it fit?? thanks a lot guys...
Re: '00 civic si lip on eg?? (kcjohnnyboy)
it will not bolt right on , but i have saw them be modified to fit , as far as i know they are a little too long , so its not impossible but however might not be worth the trouble , but it isnt impossible , so technically its not end of story it can be fitted
yes u would need to make some modification's but it fit's nicely but u have to cut about 3/4 inch on both side's... i did mine but not with the oem lip just some knock off one which is lil thicker and flexible check it out
http://www.jdmvtec.com this web site belong to fellow member (chameleon), he has a write up on it that may help you out....good luck...let see some pics
thats a great HOW-TO...im gonna do this immediately!! im a little lost about those screws though? i cant tell where they r supposed to go? the ones where he shows the left and right side pics...can anyone shed some light?
Re: '00 civic si lip on eg?? (BoostedCivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedCivic94 »</TD></TR><TR><TD CLASS="quote">also wheres the best place to buy an 99-00 si lip?</TD></TR></TABLE>
honda maybe?
honda maybe?
Solbros Owns Me
Re: '00 civic si lip on eg?? (OneSlowEF)
the contour of the lip actually follows the EG bumper close to perfect. It is just a little longer, so it needs to be cut.
On Drevinder's lip...above, we just usedcarriage bolts and nuts painted black, and went through the front of the lip. Actually turned out very well.
The stock 99-00 Si lips are plastic, whereas the aftermarket ones are either Urethane or some rubber compound .....they're actuallyu better than OEM
Re: '00 civic si lip on eg?? (hj.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hj. »</TD></TR><TR><TD CLASS="quote">this one looks nice, here in D.R
Re: '00 civic si lip on eg?? (drevinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder »</TD></TR><TR><TD CLASS="quote">yes u would need to make some modification's but it fit's nicely but u have to cut about 3/4 inch on both side's... i did mine but not with the oem lip just some knock off one which is lil thicker and flexible check it out
that looks nice as hell
Re: '00 civic si lip on eg?? (cycocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cycocivic »</TD></TR><TR><TD CLASS="quote">hey hj,
what kind of foglights is on that silver civic?</TD></TR></TABLE>
99-00 OEM
99-00 OEM
Re: '00 civic si lip on eg?? (blue i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue i »</TD></TR><TR><TD CLASS="quote">
99-00 OEM</TD></TR></TABLE>
WRONG. Thats a CTR "Style" knockoff ABS lip.
Re: '00 civic si lip on eg?? (Tokyo_X-treme_Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyo_X-treme_Racer »</TD></TR><TR><TD CLASS="quote">
WRONG. Thats a CTR "Style" knockoff ABS lip.</TD></TR></TABLE>
Wrong read it again dumb ***.
Re: '00 civic si lip on eg?? (koreanwilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox »</TD></TR><TR><TD CLASS="quote">
I've seen a similar bumper before on here. What I want to know is, "Is this an OEM eg bumper, modified with EK fogs?.... Or, is it an aftermarket bumper?" I'm guessing modified.
Re: '00 civic si lip on eg?? (AlphaQup)
OTOH there was a thread looking for these bumpers, there is a japanese company that makes bumpers for eg's that look like 99-00 civic's. a guy on the board was going to try to import them, but couldn't get prices because of the language barrier. supposedly like 300-500 a bumper
Re: '00 civic si lip on eg?? (AmginE)
Not the best pic, but you get the idea. You can make it fit, but you need brackets to hold it up front as it bows out & downward a little bit, and you need like 4-5 washers on the end if where it wraps around into the bumper, unless you want to hack it up and cut it. Looks OK but not worth the trouble to make it fit properly.
it can be done.
some guy had it posted on here.
its fits god but it gaps on each side about a inch. so he uses a screw and some double sided tape looks madd nice. ANd EBAY sells 99-00 si lips for like 40 sumthin i seen some today..
