00 Civic Si/GSR swap stalls when idling or switching gears
I have a 2000 civic si with a GSR swap. I've had the car for about 2 months, and ever since moving to Arizona, the car dies randomly when stopped at a light or even moving. I am confused because the car starts up fine every time. The car also runs really bad when the A/C is on. Any suggestions?
Re: Car dies randomly
Give more information about the stalling. Does the engine also stall when accelerating or only when you take your foot off the throttle pedal?
Any CEL codes?
Recent A/C work? A/C not working well?
Any CEL codes?
The A/C works, but it isn't consistent with blowing cold air. The engine stalls when idling or inbetween switching gears. Hope that helps.
Re: 00 Civic Si/GSR swap stalls when idling or switching gears
1. magnetic idle on AC compressor check it
2. clean your IACV using carb cleaner
3. check engine timing
4. or check ECU
4. or check ECU
I got the car tuned at local Honda genius here in KC before I made the trip to AZ. I forgot I had 93 octane in the car when he tuned it, and I have been putting 91 in it since I've been down here. I assume the timing is off?
Edit: Update- Was driving on the highway tonight, and all of a sudden the when pushing the gas, the car wasn't reacting to my foot. It made me think the fuel pump wasn't giving out any fuel?
Update: Car was bogging really bad on the highway, pulled off the hwy and the car died, then wouldn't start back up. I'm lost.
__________________
__________________
Well update. Car is getting painted and fixed and I guess the car turns over but isn't delivering any fuel. I know your first assumption is the fuel pump. I have a kill switch that is connected to the fuel pump, but that wouldn't matter if it's not on, right?
oehawks3
06-08-2012 08:14 PM
SurfLifeAway
02-08-2012 09:09 PM
