Re: 00 Civic Si - alternator not charging battery
i had a problem very similar to this. I even bought a brand new battery and it still happened. so one night i turned my headlights on and started the car, a few minutes of driving the radio would turn off and my cluster lights would dim. i replaced the battery, alternator, but still same problem. i ended up figuring the connection from the alternator to the fuse box was old and nasty so just cleaned that up and it started up with no problem! so check all your grounds and connections and all
Does the dash charge light ever stay on with the engine running?
If both top test tabs of installed fuse 15 have battery voltage and the alternator belt is tight and not slipping and no CEL codes are thrown, then replace the alternator. |
like i said alternatorrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrr yeeeeeeeeeeee, or do what i did replace everything, floor harness, dash harness, engine harness, trunk harness,headlight harness and then wire tuck lol
what is dash charge light?
alt belt is tight and i do have a CEL P0133 which was checked by autozone and said it was my o2 sensor. i have a dc header so i did the diy cel eliminator(antifouler) yesterday to trick it... ill check the wire from the alt to the fuse box and if thats nice and clean then i guess last choice is to change the alt... |
prolly a bad diode somewhere or the alternator is just going out period
Originally Posted by hialeahzbg
(Post 45202743)
...i do have a CEL P0133 which was checked by autozone and said it was my o2 sensor. i have a dc header so i did the diy cel eliminator(antifouler) yesterday to trick it... |
I don't have eld light so it must be alt then...
i tried the old mans trick by taking out the positive on the battery while the cars on to test the alternator and the car ran perfectly fine.. what else could it be?
That's a risky test that should be avoided. In addition, you already know the problem is intermittent, so take the result with a grain of salt.
So replace it then? I'll try one out
When you post. Consolidate all your thoughts and place them in an organized fashion in one single post so its not as painful to read.
Also, listen to RonJ@HT. He knows what he's talking about. He's helped me on more than one occasion. |
Oh trust me I know hes very knowledgeable and has helped me in the past before...
update... its 1:30am and i was driving home from my girls house... hids on and radio was on only... hids flickered a little bit at times and radio turned off only once... drove for about 20 mins and pulled up to my house... decided to turn on the ac to see if it dimmed the lights and i was right... car almost turned off... it literally idled like at 200rpms and came back up to 900rpms... when i turned the AC knob to blow max, i heard a click coming from the ecu side of the car... i kept turning back and fourth and i heard that same click coming from that part of the car... when i turned on the defroster everything dimmed even more... will try replacing the alternator some time this week... this car is killing me...
Changed the alternator this morning and still...
Get the helms manual and go attempt to fix/clean/repair every ground you have on that car... Your alternator shouldn't be burning out unless you have a weak/bad ground for various devices in your car.
i will try this... i know its a ground but everyone ive checked seems tight...
i think ur engine harness might be shorted, i changed mines out after it threw lights on my cluster, but not a full guarantee i spends almost near 2k just fixing all my electrical issues to near new
damn and theres no way of testing it?
engine harness testing nope, i took mines apart it took so long to test so i was like fck it imma just get another one lol
but b16a harness are hard as hell to find nowadays... back in 2003 it was cake... now this shits rare!
shits must suck for you , doesnt obd2-b b18c1 or c5 harness works properly the same way
nope its different...
u sure we use it for swaps all the time
(Post 45208894)
These are old cars now, things will corrode and get dirty so it's our job to do these repairs and to do anything but is pure neglect. If you could get an ohm meter (multimeter with ohms function is the same) and measure the ohms from the ground point to battery, it can be a good indication of how well the ground is working. You can't just visually inspect grounds, you've got to actually check em. |
on egs yea but not on em1's...
