00 Civic - Need part ID for front-end component
I know this is part of the LCA, but I need to know exactly what the broken part is called (so I can search for it separately w/o buying a whole LCA assembly).
Ran over a steel I-beam @ 60mph dropped off a truck... Rad support is trashed as well as 3 wheels but I have this under control. Frame looks fine, won't know until I get it on alignment rack. Drove it home (~40 miles) on two donuts like this (one borrowed) so I have some hope (wouldn't have done so had I known the damage)... We'll see...
Re: 00 Civic - Need part ID for front-end component
I don't think those can be purchased separately.
Majestic Honda Parts: Front Lower Arm
It looks like the bolt broke. Just remove the bolt from the control arm and install a new bolt.
Assuming I have to get the whole thing, should I use this as an excuse to get some aftermarket LCAs, or just get used OEMs?
Correct, but it can be pulled out. It'd definitely the cheapest option, maybe easiest depending on how hard its to find junk yard parts.
That wheel is basically what three of them look like. That sidewall/rim damage is actually from running *over* the I-beam. Only 4K miles on those tires (Michelin MO1 so definitely not junk - 100K on my last pair, same car)...
Wondering if the tire failed where it did because of the location of the weight? Coincidence?
Espincivic
12
04-27-2016 07:20 PM
jdmsupreme2132
Suspension & Brakes
11-06-2009 03:19 PM
killaj12
11
05-10-2007 06:10 AM
