00 Civic DX has codes 8 & 9 - Need help with DIY Distributor replacement
#26
Re: Need help with DIY Distributor replacement
I re tested the new dizzy pin out for resistance all is good
how do i trouble shoot from the dizzy connector to the ecu?
#27
#28
still trouble shooting this cel 9 code so i have been trying to test all the wiring between the dizzy and ecu.
So i found the pins in the ecu connector for the dizzy , they are showing a resistance of 350 ohms. I don't have a continuity tester on multi meter.
i tried to test the connector the dizzy plugs into but i couldn't get a reading off of it
any suggestions on what to do ?
#30
#31
Key off -- Unplug the ECU connector that has the two CYP terminals. Set multimeter to read resistance on the lowest scale (e.g., 20 or 200 Ohms), if it does not auto range. Touch one meter probe to one CYP terminal in the ECU connector and the other to the metal frame under the dash.
#32
Thank you soo much . Should i discnnect the neg battery terminal ?
and how much resistance am i looking for?
I just tested it and it gave a reading of 1 which I'm pretty sure mean there's no circuit and it's grounded???
#33
Not necessary but it wouldn't hurt either.
Infinite/Too high to measure
1 Ohm?
#34
1 meaning infinite /to high to messure...
So I'm pretty sure this means everything is grounded?
ay suggestions on what to do now?
#35
#36
Thanks ron
both pins are showing as being infinite/to high to measure.
When it come to ecu's i'm in canada and if i buy a ecu off ebay from the states will it work in my Canadian car?
#37
U.S. and Canada ECUs should be the same, but if you can borrow one for testing purposes, do that rather than buy. What car/engine?
You also might want to check whether the code is still thrown after unplugging and replugging the ECU and distributor connectors, just in case there was just a bad connection.
#38
so its a 00 civic dx d16y7 p2e ecu ....
i i really don't know where i would find one for testing purposes
everything is hooked back up and i guess we will see if it throws the code again now
Ron you have been a huge help with all this thanks so much !!
Kaminsky
14
08-07-2015 03:03 PM
meallout
03-19-2009 11:01 AM
coocoobird79
04-22-2008 07:24 PM
