00 Civic - CEL doesn't work
Old 04-15-2015, 05:15 PM
sweetpink's Avatar
Default 00 Civic - CEL doesn't work
So went to get car smogged and they say that the check engine light should come on and go off well it doesn't so he needs to open the dash to see if its burnt out or someone tampered wirh it, i did buy it used. The car runs great. No smoke or anything. Anyone have any knowledge? I just didn't have the funds for the guy to do it today. Kinda freaking out
Old 04-15-2015, 05:23 PM
craklingice's Avatar
Default re: 00 Civic - CEL doesn't work
I am not sure what car you are driving but if you google LED gauge cluster how to for your car then you should be able to find out how to replace the bulb that way.
As far as the light coming on, it should come on and go out when the car is started. If your car is '95 or newer I would like to think that a simple code scan and a 'you should fix that' should have been enough to get you through smog.
Old 04-15-2015, 05:29 PM
sweetpink's Avatar
2000 honda civic. the guy said the light should go on and off when he starts the car but it isn't. So it should just be the bulb? Thanks for your reply.
Old 04-15-2015, 08:37 PM
I never narc'd on nobody!
NotARaCist's Avatar
Yes, when you first turn the key to ON(II), it should turn on for ~3 seconds, then turn back off. If it doesn't, then the bulb is probably burnt out. See this thread.
Also, before creating threads in the future, please familiarize yourself with the rules sticky at the top of this subforum. "help" is not an acceptable thread title, and the OP must include car information, as well as any relevant modifications. Super simple rules.
Old 04-15-2015, 08:39 PM
Former User's Avatar
Default Re: 00 Civic - CEL doesn't work
This^
Title edited, and please do visit the Rules sticky.
Old 04-15-2015, 09:24 PM
sweetpink's Avatar
I apologize but I actually didnt create a title, I think it generated one. I will remember next time. Thanks for the responses but the people who sold me the car took the light out to mask 4 different codes .
Old 04-15-2015, 09:27 PM
NotARaCist's Avatar
And the next time you buy a car, you'll know to check that the CEL comes on, then turns off. Both of my Hondas have done it, both of my Subarus do it, and even the 2500HD does it. I'm not going to say for sure that it's an industry standard type of thing, but at least from what I've seen, it's a safe bet.
And yes, you did make the thread title when you created the thread. That's how forums work.
Old 04-15-2015, 09:39 PM
sweetpink's Avatar
Absolutely . I don't know the first thing about cars of any type,but slowly I'm learning the basics.
I apologize for the issue. I was just desperate to find out and didn't bother reading the rules. Clearly.
Old 04-15-2015, 09:42 PM
NotARaCist's Avatar
It's all good, **** happens. You're already doing better than most first time posters do
Given your self-admitted newness, you might also want to give the FAQ sticky a read. There's a LOT of information in there for someone just like you.
Old 04-15-2015, 09:47 PM
sweetpink's Avatar
Thank you for the help. I've read through the rules and will also be reading the sticky faqs.��✌
Old 04-16-2015, 12:44 AM
Fish Twig
tony_2018's Avatar
God damn, first noob to post an honest mistake. Repped if possible.
Youtube check engine light 2000 honda civic and you'll see where the bulb is suppose to be. From there if you google on how to remove gauge cluster you can replace the bulb that way.
Old 04-17-2015, 07:49 PM
hcv1122's Avatar
You might want to check the bulb itself behind the cluster, it's easy. 2 bolts for the cover, and 4 bolts for the cluster itself. As soon as you disconnect the connectors you can pull the cluster out and try swapping bulbs, worth a try.
Old 04-18-2015, 03:03 AM
NotARaCist's Avatar
And you might want to check a thread before saying what multiple people already have.
CERTIFIEND
07-26-2015 11:28 PM
Needhelpplease1
11-17-2013 06:59 PM
924drb20
08-19-2010 07:59 PM
knowledge112
04-28-2005 09:44 AM
No
07-10-2004 05:10 AM
Quick Reply: 00 Civic - CEL doesn't work
