‘00 Civic DX Coupe Transmission Noise - Honda-Tech - Honda Forum Discussion
Old 10-09-2017, 11:49 PM   #1
Default ‘00 Civic DX Coupe Transmission Noise
I’ve got an EK coupe with the stock Y7 (stick). The car has been making this funky noise coming from the tranny. It sounds like one of the internal bearings? Please note: the noise goes away every time I push in the clutch pedal.
Here’s a video where you can really hear it:
sd_swordfish is offline   Reply With Quote
Old 10-10-2017, 02:21 PM   #2
civic402lx's Avatar
Default Re: ‘00 Civic DX Coupe Transmission Noise
Could be throw out bearing noise.
civic402lx is offline   Reply With Quote
Old 10-10-2017, 07:47 PM   #3
Throw out bearing or input shaft bearing or both. Most likely, throw out bearing...
EchoMike1 is offline   Reply With Quote
Old 10-12-2017, 12:17 PM   #4
LiteraCola's Avatar
If the sound is there with the clutch out. it's most likely one/both of the Main Shaft Bearings. If the sound is there with the clutch in, it's the TO bearing. Just went through this last year. Changed all the trans bearings, including the clutch/flywheel and throw out bearing, all good now.
LiteraCola is offline   Reply With Quote
Old 10-12-2017, 03:25 PM   #5
Intelligently Stupid
TomCat39's Avatar
The ISB is known to sound like a cricket chirping when it gets bad.
Pushing in the clutch pedal lets the input shaft stop spinning and the sound goes away.
Throwout bearing, when bad, usually creates the worst sound when the clutch pedal is pushed in as that is when it is most loaded.
TomCat39 is offline   Reply With Quote
Old 10-13-2017, 10:34 PM   #6
Do you know how many miles since the last clutch job? If you don't know or it's been more than 50k, might be worth doing one.
rfmerrill is offline   Reply With Quote
Old 10-14-2017, 10:12 AM   #7
tony_2018's Avatar
throw it bearing or the getting shafted bearing
tony_2018 is offline   Reply With Quote
Old 10-14-2017, 06:43 PM   #8
Quote:
Last clutch job was about 3 weeks ago. Took it to a local shop, had the clutch and flywheel replaced. They installed the O'Reilly "Powertorque" clutch kit and flywheel, along with the throwout bearing. The clutch kit was $120, $60 for the flywheel; brand new from O'Reilly. But now I'm thinking it's the input shaft bearing as TomCat39 said. The sound goes away once the clutch pedal is pushed in. They must have not replaced the ISB, but I'm not sure if the kit came with one?
Old 10-14-2017, 06:45 PM   #9
I think you might be right. It sounds just like a cricket chirping when the car is idling (as seen in my video). It goes away completely when I push in the clutch pedal.
HELP! Mystery noise. Rick Overton Acura RSX DC5 & Honda Civic EP3 1 07-02-2017 04:25 PM
What is this rattling noise, valve train? alextech Honda Civic / Del Sol (1992 - 2000) 11 06-21-2017 11:58 AM
1992 Accord - Distributor Making Noise jlwallnc Honda Accord (1990 - 2002) 3 01-21-2016 03:14 PM
*** Starting issues, please help me! *** doeboy208 Honda CRX / EF Civic (1988 - 1991) 3 11-13-2015 01:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
