[FAQ] What parts are interchangeable for all 92-00 Civics? - Page 15 - Honda-Tech - Honda Forum Discussion
Old 08-22-2018, 05:56 AM
  #351
Intelligently Stupid
TomCat39's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics?
no
TomCat39 is offline
Old 09-12-2018, 04:48 PM
  #352
Default Re: (xtremeazian)
Originally Posted by SOHC4life 96 View Post
Springs/coilovers for '94-'01 integras and '92-'00 civics are interchangeable. The only difference is the spring rates.
what about 03 lowering springs on a 2000?
Smostej6 is offline
Old 09-12-2018, 05:56 PM
  #353
Freedo_Civegra's Avatar
Did you even look at pics of the setups?
Freedo_Civegra is offline
Old 01-07-2019, 12:28 PM
  #354
Does a acura 1.6el under dash harness fit in a 99 civic?
BrutalmickQC is offline
Old 01-13-2019, 08:59 PM
  #355
thank you ive been trying figure out what tranny will fit in my d16z6 engine for a 1995 civic.
Henry Arinaga is offline
Old 01-14-2019, 11:29 AM
  #356
TomCat39's Avatar
Manual or Automatic?
TomCat39 is offline
Old 01-14-2019, 04:07 PM
  #357
Oh look, I can change this
deschlong's Avatar
I believe so. Well be careful for ODB2a vs ODB2b etc. Main difference is the climate control system but I believe that's on a separate subharness. Anyway, you could also take this opportunity to convert to the 1.6EL climate control, which is a nice upgrade(?).
deschlong is offline
Old 01-14-2019, 10:35 PM
  #358
wow. im really stoned tonight after work. cant sleep. i literally just read thru 15 pages of this thread. im new here. thanks to all who dropped the knowledge. this community is rad
grilledcheese is offline
Old 02-05-2019, 05:38 PM
  #359
So im guessing that all d series share the same oem air intake?
Wolftown is offline
Old 02-06-2019, 09:52 PM
  #360
n*werk's Avatar
nope, 96-00 civic d series intake has the IAT on it.
n*werk is offline
Old 02-08-2019, 11:22 AM
  #361
BiggieBert's Avatar
when you say intake, do you mean manifold or air box? There are variations based on generation and submodel. I.e. a D16Z6 and a D16Y8 have different manifolds, but are swappable depending on car and harness, but that can be worked around.
BiggieBert is offline
Old 02-08-2019, 11:35 AM
  #362
TomCat39's Avatar
Quite a bit of work around as the fuel rails are not even remotely the same and are not interchangeable between the manifolds you just mentioned. This means you have to contend with the regulator being on opposite ends as only the injectors could be swapped while maintaining the rail that mates with the manifold.
TomCat39 is offline
Old 02-08-2019, 12:34 PM
  #363
BiggieBert's Avatar
by swappable I simply meant they share the same bolt pattern when mounting to the head.
Old 02-08-2019, 02:04 PM
  #364
TomCat39's Avatar
I don't get why the injectors holes don't match as it seems to me the intake ports are the same spots on both heads or there would be problems swapping intake manifolds. But when I was comparing fuel rails (wanted to put the B7 rail on the Y8 manifold. I noticed the injector holes don't line up so I can't even drill now mounting holes for the mounting studs.
I'll have to look at that again as it seems odd.
TomCat39 is offline
BrakeExpert
Suspension & Brakes
403
01-14-2019 11:59 AM
Syndacate
08-27-2018 12:02 PM
DevinW
02-15-2018 03:49 PM
stackz
103
10-11-2016 04:46 AM
Redline96LX
157
05-31-2016 09:16 AM
Quick Reply: [FAQ] What parts are interchangeable for all 92-00 Civics?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
