[FAQ] How To: Wiring VTEC into an EG non-Si Civic (that's not a 92) OBD1 w/p28
#26
Re: How To: Wiring VTEC into an EG non-Si Civic (BelgiumEG6)
could you or someone else please post a pic for me of the ecu harness side which wires need to be added where
thanks and good write up
#27
Re: How To: Wiring VTEC into an EG non-Si Civic (crvpimpin)
how do I wire up a 4 wire o2 sensor. i have a 95 cx. and a b16 engine harness.
the harness from my ecu to the engine bay is only wired up for a one wire?
#28
Re: How To: Wiring VTEC into an EG non-Si Civic (shivic)
A good write up, but more info needed!! I have a 94 vx, stock engine harness, Gsr swap with p28 hondata s300, do i need to do this mod??????
#30
im using a stock VX harness. dropping in a D16z6 vtec. do i have to convert my 5 wire 02 sensor for a 4 wire 02 sensor. if so how do i do this? thanks in advance.
#33
so i can install a b16 with a ex harness corret!!! with out having to mess with the wiring for the ecu?? what about the knock sensor??
#36
Re: How To: Wiring VTEC into an EG non-Si Civic (that's not a 92) OBD1 w/p28 (ARIZONA)
ok so what i am gathering i hope is when i swap my d16z6 ex wiring harness to my stock 1993 dx and wire the vtec and oil pres to my p28 that should be all i need for wiring up my engine???
#37
Run a p28 then you don't have to worry about that little knock sensor will plug right into obd1 i have a p28 for sale but its modified for a type r shift a 9000 rev limit at 9200 to be safe 3500 vtec kick in usb cord to hook to laptop to display dyno and gauges just one problem my laptop screen broke would have to send you my hard drive with it so you could get the program
#38
Re: How To: Wiring VTEC into an EG non-Si Civic (gillyfesh)
https://honda-tech.com/forums/tech-misc-15/wiring-gurus-obd1-motor-obd2-harness-pic-extensive-2203580/ THIS TELLS AS STEP BY STEP CANT FAIL IF YOU FOLLOW INSTRUCTIONS
HATE TO BURST YOUR BUBBLE BUT YOU GOTTA GET THE NON VTEC P28 TUNED FOR VTEC
#39
HATCHingMN
06-29-2004 02:24 PM
