[FAQ] EG with b18c1 and air conditioning
Im having a little trouble getting the air conditioning to work in my eg. It has a b18c1 swap and that is where the problem comes in. The comprressors for the b-series engines have different entry points and the bolt used to secure the hose to the compressor is located in a different position, just about 90 deg. That wouldnt be a problem but the one stock eg hose has a bend and you cant simply rotate that hose to accomodate for that 90 deg. difference in the position of the bolt.
My first though was to get the Integra hose but it travels around the bottom side of the radiator in a round-about-way that i dont think will work on my civic with the half-width rad.
Has anybody else encountered this? I would like to find a stock solution rather than cutting and welding the stock hoses.
Re: EG with b18c1 and air conditioning (blbvtec)
Use your Civic AC Compressor and all the lines from your EG. Then, buy a 93-95 Del Sol VTEC (P54) AC Compressor mount and it will all bolt up perfectly
Former Moderator
Re: EG with b18c1 and air conditioning (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">Use your Civic AC Compressor and all the lines from your EG. Then, buy a 93-95 Del Sol VTEC (P54) AC Compressor mount and it will all bolt up perfectly </TD></TR></TABLE>
Exactly.
This is covered at least 3 times a week lately.
Did you even try the search function first?
Exactly.
Re: EG with b18c1 and air conditioning (Skip01)
http://www.slhondaparts.com 1994 Del Sol VTEC AC Mount Bracket part number 38930-P54-000 $110.61.
Re: EG with b18c1 and air conditioning (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic »</TD></TR><TR><TD CLASS="quote">this will also work with an ek right?</TD></TR></TABLE>
It will work exactly the same in an EK. I did it 2 weeks ago actually.
haha
$110.00 i dont think so.
ill have the local hydraulics shop refit the end
though i am appreciative of the replies
Re: EG with b18c1 and air conditioning (BrewerHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewerHatch »</TD></TR><TR><TD CLASS="quote">Who needs A/C? </TD></TR></TABLE>
Exactly It's been over 2 years since I have had AC or PS, I am hardcore
Risky Business
I am hardcore </TD></TR></TABLE>
Yeah, a hardcore dumbass.
Re: EG with b18c1 and air conditioning (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Yeah, a hardcore dumbass.</TD></TR></TABLE>
eh, who's car is faster? And it's ALL because of the AC (or lack of it). No other reason but AC removal
Risky Business
eh, who's car is faster?</TD></TR></TABLE>
They are equally fast...when dropped from an airplane
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">They are equally fast...when dropped from an airplane </TD></TR></TABLE>
**** newton!!!
i have a/c with my b18c1 swap.. i dont remember how we rigged it up though.. i dont think i got a del sol bracket though..or maybe i did.. hmm it was too long ago to remember, sorry. I dont even remember the last time i used my a/c though, but it has been winter for the past 6 or 7 months.. damn ohio..
**** newton!!!
Re: (hatchy92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchy92 »</TD></TR><TR><TD CLASS="quote">Use your Civic compressor with the gsr bracket- though only two bolts will bolt up, thats what ive been doing, been good ever since!!</TD></TR></TABLE>
I have heard of that being an option, but never really thought it would work. But, I guess if you have it actually up and running like that with no problems, that could also be one way of tackling the problem. Which two of the four bolt holes line up?
Re: (b16a ferio)
Just becareful when you only use the two bolts, don't have your belt really tight. My compressor came right off and it was dangling from the two hoses. the belt came off too. The shop that check the AC tighted the belt so tight. I was angered.
Re: EG with b18c1 and air conditioning (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Did you even try the search function first?</TD></TR></TABLE>what's that Tom? Fill me in. I've heard of this function before, BUT never seen it!
Re: EG with b18c1 and air conditioning (thebonniesong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thebonniesong »</TD></TR><TR><TD CLASS="quote">
It will work exactly the same in an EK. I did it 2 weeks ago actually.</TD></TR></TABLE>
what about that mount that is next to the a/c bracket where can i get one of them from
Re: EG with b18c1 and air conditioning (Mr. JDM-GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. JDM-GSR »</TD></TR><TR><TD CLASS="quote">
what about that mount that is next to the a/c bracket where can i get one of them from</TD></TR></TABLE>
ues your existing one. it comes off with a deep 14mm socket.
Re: EG with b18c1 and air conditioning (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 »</TD></TR><TR><TD CLASS="quote">**** newton!!!
i have a/c with my b18c1 swap.. i dont remember how we rigged it up though.. i dont think i got a del sol bracket though..or maybe i did.. hmm it was too long ago to remember, sorry. I dont even remember the last time i used my a/c though, but it has been winter for the past 6 or 7 months.. damn ohio.. </TD></TR></TABLE>
BEST REPLY EVER!
wow.
BEST REPLY EVER!
wow.
**** newton!!!
Take a deeep breath.......ok.......Now..........Exhale......... ..Good
**** newton!!!
Re: EG with b18c1 and air conditioning (dohcVTEChatch)
live in a desert area and ask "who needs a/c"? its 102 daily NOW, and gets to 115-120 in the summer, and at its worst in august... have you ever passed out from a heat stroke or heat exhaustion? now imagine that happening behind the wheel of your prized possession... i don't care how hardcore you are, unless you're stupid you'll have it.
do as mentioned above to get your a/c workin, good luck.
