[FAQ] ECU Codes for everyone
#253
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">the VSS is the only sensor that is going to your transmission if its a 5 speed. its straight down from the throttle body</TD></TR></TABLE>
He has an auto though. Is it in the same place?
#254
Re: (Chiovnidca)
im getting a code 19 on a jdm p30 ecu which indicates an automatic transmission lockup from all the lists I can find. The swap is a manaul transmission. Does this mean that I got an automatic p30 ecu? Do they exsist? or does the code 19 stand for something else in a manual transmission??/
Thanks for the help
Thanks for the help
#255
yes the vss should be in the same spot. i believe its a 3 wire sensor.
For your code 19. yes that is a automatic ecu. the reason its throwing a code is because the ecu is looking for that sensor hence its for a automatic tranny.
#256
I have a 92 Civic HB w/ a 96 GSR swap. I'm using a JDM B18c ECU (Has 4 connectors on the ECU). I'm thinking it's for the JDM Automatic B18C's. I'm getting a Check Code 21. The wires are connected right but still receiving this error. I swapped it out with my friend's USDM ecu and it still gives me the same error. What else can I do?
#259
Re: ECU Codes for everyone (JDMlifestyle)
Get this... My 99 Si is throwing a code 76!? That is a random misfire on cylinder #6 in a B16? Curious. Any idea as to what might be wrong?
Also, I have checked and rechecked and I am sure it is 76.
#264
i am flashing a code 40????? 98civic d16y7 that has been changed to a 94' d16z6 and changed the ecu to a p28 any suggestions
#265
Re: (Chiovnidca & JDMlifestyle) Locating the 3-pin VSS
OK...I found it...the question is, "How do I get to it?"
I can easily hit one of the bolts with an extension...the other is impossible from what I see.
FYI - I found the VSS on eBay through Direct Automotive Products; $51.70 delivered.
Once I recv it I will try and get at the old one.
My mechanic says he will do it for one-hour labor; but I would really like to do it myself. Any suggestions?
I have the service manuals coming in the mail...one on CD ($4.50 delivered) and the original Honda Service Book ($11 delivered - it's heavy).
Aaron
94 Honda Accord EX Auto
Modified by emsAARON at 12:44 AM 6/18/2004
Aaron
#266
I just tried this in my 1999 DX hatch and had a problem. The light has been on for a few weeks. I found the connector (had a brown wire, not red) and jumped it. I turned the key to the on position without turning on the car. The CEL immediately went out at this point without flashing at all. I turned the key off and back on again and the CEL just went off again without flashing. I took out the jump wire and I turned on the car and the CEL stayed off. It stayed off for two days, now it just came back on. Am I doing something wrong? Thanks for your help.
#267
Re: ECU Codes for everyone (Alwysfresh)
Originally Posted by itsm3paul
im throwing a code 16 with is the fuel injectors? should i replace all my injectors or whats a good way to fix this problem
Originally Posted by warwagon
wow!!! does 41 mean its wired wrong or i need a new sensor?
how do i fix cel 16? i checked my injectors they seem normal i cleaned them but im still throwing the code let me know thanks
Aaron
Aaron
#268
I'm not sure if it's the right one. I found the one just hanging there unconnected to anything in the green rubber protection bootie with two wires coming out of it...one black, one brown. The CEL was on initially, but it went out after I jumped it. Where is the other connector located? Does it sound like I have the wrong connector? Thanks for your help.
#269
DOES ANYONE KNOW WHAT CODE 18 IS? for some reason my ecu is pulling that code up i've got a gsr in my eg but I was thinking that it could possibly be my hondata cause there is not a code for 18 and I just had it installed thanks
#270
I checked my code, once again, and it is now reading a code 67. I don't know how I read it wrong or if I even did and the computer is just freaking out, but it is probably not just a coincidence and I am an idiot. Anyhow, code 67 is not on the list either, but I assume it is because of a problem with an O2 sensor by where it is on the list. I had to splice the sensor wires because they weren't long enough to fit my header. Any ideas now? Bring on the flames... I deserve it.
#271
Re: ECU Codes for everyone (Wilky)
Is the process any different for getting the ECU codes for a 1994 Honda Accord.
Heres what my cars doing:
1) D4 light blinking
2) Speedometer/odometer/tripometer dont work-even after replacing the VSS
3) ABS light comes on after putting the car in drive.
Thanks for any help!
#274
Re: (JDMlifestyle)
Thanks JDMlifestyle for the codes and video. I've hooked up paper clip and get 17 blinks on CEL (VSS), 4 on my D4 lite, and 4-8 on my ABS lite.
The problem I've got now is I've already replaced the VSS about 4 mos. ago, which I bought on Ebay. Is it possible I got a bad unit (seeing how it never worked from the minute I put it in). This evening I removed the VSS and checked the current of the harness and everything seems right. Reinstalled and damn thing still doesn't work. On top of that, one of the heads to the bolts broke off!!! Now I'm really frustrated, but the beers tasting good! Any ideas where I go from here????
#275
Re: (JDMlifestyle)
Maybe a stupid question.
I have Civic '93 with D15B2 engine and it's for Europe market. Does this code aplyed to my Civic?
How I wil recognize if CEL flashes for two or more codes. For expample: 32 and 45.
I if hook up wrong pins/wires is there any damage?
Sory for bad english, it's not my nathive language
Greeting from Croatia, Europe
