Burning Oil.
Burning Oil.
So my friend rebuilt my motor, two weeks later it blows. So I take I bite the bullet and take it to a shop for a hg replacement and to check the head for warping. So after that it blows again. Being fed up with the whole deal I buy another car and leave my DA alone. One year later I decided to do some work and check out my block. So, I drop the oil pan and "wtf is that"? It was a torn off peice of a latex glove stuck in the oil pump filter. My real question being, would that have caused my car to overheat and blow two head gaskets that quick?
Re: Burning Oil.
Don't replace your car..replace your friend that has piece of his glove missing...lol
It's possible but I'm surprised a CEL or engine oil light didn't come on. During the rebuild did you purchase and have a new water pump and thermostat installed? DId you or your friend check pistone compression at any time? Was the cylinder head ever taken to a machine shop and resurfaced to spec? Was the block's mating surface ever checked for straightness within spec?
You're leaving out a shitload of details that may help besides a piece of glove found in crankcase. Obviously though anything other than oil in crankcase is not good.
Re: Burning Oil.
Lack of oil = lack of lubrication, lack of lubrication is metal on metal contact which will cause a HUGE heat problem = warping metal and gaskets.
Avoid any of the people that helped you before.
hondaracing1
13
03-31-2004 04:32 AM
