[FAQ] DIY How-To: 96-00 hatchback/trunk water leak fixes
Old 05-24-2008, 05:26 PM
  #26
Aquafina's Avatar
Clean up the rust. Prime it with weldable primer, then weld some sheet over it and paint. Thats what I would do if my plug was rusted.
P.S. Still no leaks from them.
Old 02-02-2009, 01:06 AM
  #27
BlueIntegraBoy's Avatar
Default re: [FAQ] DIY How-To: 96-00 hatchback/trunk water leak fixes
I wonder if they sell the craft foam long enough Integra tail lights. Hmm...
Old 03-23-2009, 12:02 AM
  #28
96civicexrican's Avatar
I have this problem in my 96 coupe (non hatch) and 94 hatch is this also the solution? LMK
Thanks,
Nick
Old 04-21-2009, 03:57 PM
  #29
Nino_eg6's Avatar
good thread!
Old 08-19-2009, 09:14 AM
  #30
smiko0124's Avatar
yeah i know its old but im bringing it back... Pics dont show up on my macbook. can someone email them to me if they are still linked?
smiko0124@yahoo.com
Thanks in advance.
Old 10-24-2009, 12:34 PM
  #31
New User
Potholing's Avatar
This looks like great advice, and I dig rootbeer, but can somebody repost the pics? They aren't showing up five years later, and this is linked to the FAQ.
Thanks.
Old 10-31-2009, 12:01 PM
  #32
Mike Jones
SlowPokeEg's Avatar
Thanks.
x2
Old 10-31-2009, 01:41 PM
  #33
Weifast's Avatar
I know the OP offered a cheaper suggestion, but I couldn't find the craft foam, so what I did instead was to just go down to honda and get the replacement gasket (you can't double up on the gaskets as some have previously said, it's a lie. The foam is too thick when you double up and the taillights stick out WAY to far. Although you can bolt it down, I doubt you want your taillight sticking out 1cm with a huge gap on the side). I got automotive sealant and just sealed both sides of the foam (to the taillight and to the chassis). My mechanic told me this is the best solution... and it worked out great. I got ZERO drops into the back of my trunk after this process and he says after this, there isn't any reason to have to ever replace the gasket again and definitely something Honda should have done from the very beginning...too bad the design of the taillight is too awakard to change bulbs without having to remove the taillight -_-
Old 11-30-2009, 07:42 PM
  #34
ek_dee_foo's Avatar
Ive gotta 00 civic hatch and i bought taillight gasket for it and i still leak water i been trying to see where the water lkeak from but can't seem to find it can somone help thank you
Old 03-05-2010, 12:00 AM
  #35
818ek9's Avatar
good thread
Old 03-05-2010, 05:37 AM
  #36
ken9's Avatar
You can try getting a water hose and spray water at the rear.. It might help pin point the water leak..
Old 10-17-2010, 03:09 PM
  #37
creationz's Avatar
GREAT POST! Cutting my foam out right now. I was able to find the foam at walmart in the craft section for people hard pressed to find it. It seems just a tad thinner than the gasket but fits a lot better as you can custom cut it all. I would recommend cleaning all the old silicon and foam before trying to lay the new one in.
Old 10-18-2010, 07:46 PM
  #38
confidence's Avatar
i used the craft foam from wally world too. You're right Creationz, its is kinda thin. So i used double sided carpet tape to stick 2 pieces together to make thicker gaskets. The bad news is that stuff eventually wears out and leaks just like the OEM foam. I just had to replace my 2nd pair of diy gaskets. So this time i made gaskets from a rubber mat i got from McMaster Carr, so far so good. I'm hoping it won't eventually leak like the foam does
Old 02-22-2011, 03:45 PM
  #39
Aquafina's Avatar
Still no leaks.
I'll go ahead and make another set soon though so I can add some pics back to the OP since I no longer have the originals.
Old 11-30-2011, 07:17 AM
  #40
sacek69's Avatar
Soond like my problem ,,, Would help to see the pics though ,,, Is there a reason why we can`t see them ??? Thanks
Old 02-28-2012, 04:14 PM
  #41
wkand's Avatar
HI:
Great Thread!!
This is my first post. I am new to the forum. I own a 1988 Civic LX 4 door with water leaks in the trunk. Which is the right section of the forum?
I have fixed the following:
1) Taillight gaskets,
2) A cracked taillight housing (water was sloshing inside the housing, and splashing inside the trunk),
3) A leak in the trunk lid seal,
But there is still water coming into the trunk from somewhere. I need to get a friend to run water over the rear part of the body, I guess.
Old 12-07-2014, 08:05 PM
  #42
bdj1973's Avatar
I found mine right after I bought the car, someone had drilled holes in my trunk as to let the water out after it rained, and my trunk smelled all moldy. So I was on a mission to find the source of the water. And I did. I took the Side pillars off, be careful the clips that holds them on will break. Anyway there are several areas where screws and such under those pillars that are not water tight. I siliconed the crap out of everything under those pillars, and the sprayed Great Stuff around the edges of the pillars and reinstalled them very quick before the Great a Stuff dried, this sealed the pillars back on where I broke clips, and also gave the pillar an addition water tight barrier. I have had a dry trunk ever since!
Tulpsrainbird
10-24-2016 06:30 AM
tadashisan
10-22-2008 12:07 PM
kixcrx
12-11-2007 03:57 AM
Kafelatte
03-21-2007 08:54 PM
PatrickGSR94
11-25-2004 02:06 PM
Quick Reply: [FAQ] DIY How-To: 96-00 hatchback/trunk water leak fixes
