K2 motor foglight install(wire diagram)
Ok my friend ask me to help him install his foglights on his 00 hatch, since I installed mine with help from you guys on HT(thanks guys). I tought it was the same oem honda one's I have but it wasn't.He has the replicas from K2 motor, and they didn't come with install instructions. So i still had the instructions for the install on my oem one's so i figured i would use that.Everything was good untill we got to the wire harness for the fuse box inside the car..It seemed like his had less wires than mine. Does anyone know where I can get the wiring diagram for these foglights. Some wires plug up but i had like 2 left that i had no idea where they went..thanks for the help..
Re: K2 motor foglight install(wire diagram)
the 1 pin brown harness has to be spliced onto the stock fog light wire. The stock fog light wire is also a 1 pin brown harness with a blue/red wire going to it (on a 2000 SI). Splice ur wire and the fog wire, its found by the bumper usually near the washer fluid tank(driver front). Then go under to your fuse box and find the other end to the factory fog wire, AGAIN there should be a 1 pin brown harness just chillin behind ur driver interior fuse box, Connect the harness to the fuse box in a "empty" slot. it will fit
