car won't start, help needed
Old 06-07-2011, 05:37 PM
Eg Fool's Avatar
Default car won't start, help needed
hey guys i own a 94 civic coupe. it has a jdm d15b in the car, but everything else is oem. i have been driving it with no issues but tried to start it this morning and it woult not start.
i hear no click so i tried to jump start it, that did no good and got the battery tested and the battery is perfectly fine. the starter was replaced around 5 months ago with a brand new one, at the same time as the battery.
everything powers up and works fine, but when i try to turn it over i hear no sounds. i can hear the fuel pump prime but that is about it. any suggestions? i'm at a loss at the moment.
Old 06-07-2011, 07:09 PM
Former User's Avatar
Default Re: car won't start, help needed
The red arrow points to a rubber stopper that presses on the starter switch at the top of the clutch pedal. Did it fall out or break?
Old 06-07-2011, 07:25 PM
95EG2's Avatar
try tapping on starter solenoid and get someone to turn key while u bang and see if it starts(i know u replaced the starter but the way u explain it could be a defective starter)
Old 06-07-2011, 07:29 PM
Eg Fool's Avatar
about to check
Old 06-07-2011, 07:30 PM
r_Senik's Avatar
do what ronj posted up.
Old 06-07-2011, 07:38 PM
95EG2's Avatar
and check all fuses under hood and under dash
Old 06-07-2011, 07:39 PM
Eg Fool's Avatar
that piece is missing, i pressed the clutch and button and had someone turn the key and it fired right up! thanks for the help man! any idea on how to get around this? i'm looking for things to shove through there right now
Old 06-07-2011, 07:52 PM
Some people hot glue a penny over the hole.
Old 06-07-2011, 07:54 PM
Eg Fool's Avatar
i've got a hot glue gun, and some change, time to get to work. thanks again! you guys really made my night
speedfreek128
Honda S2000
03-13-2015 07:49 AM
ogshokka
11-08-2010 09:46 AM
skinnyshugg
09-05-2006 08:51 PM
Fatboy1985
12-26-2003 02:38 AM
mingchi69
07-14-2003 06:14 PM
Quick Reply: car won't start, help needed
