[DIY] OEM JDM/EDM 1992-95 Honda Civic Low Fuel Indicator Retrofit
#26
Premium Member
Re: [DIY] OEM JDM/EDM 1992-95 Honda Civic Low Fuel Indicator Retrofit
Cluster Wiring
- You should send your wire through the OEM connectors in the wiring harnesses as you progress towards the cluster. “tlarimers” DIY gives great instructions on how to do this, and I recommend you follow it, so I will not expound on the point.
- Connect your wire to the cluster wire with pin that you salvaged.
- Insert this into position A7 of the cluster connector. (Figure 8)
deschlong
83
03-22-2024 12:29 AM
W0oT
16
03-25-2005 06:39 AM
naya1civic
06-13-2004 03:59 PM
