[DIY] OEM 92-95 Honda Civic Lights-On Chime Retrofit (no RadioShack crap here, folks) - Page 3 - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
Old 03-15-2013, 10:40 PM
  #51
Oh look, I can change this
deschlong's Avatar
Default Re: [DIY] OEM 92-95 Honda Civic Lights-On Chime Retrofit (no RadioShack crap here, fo
Nothing in this upgrade suggests you would lose your INT wiper function. Not sure how you read that.
Your hatch is USDM, even if it was built in Canada. All of them were.
Your VIN link also shows that a VIN that has "2HGEH236" is a DX, so you have a DX.
deschlong is offline
Old 03-16-2013, 12:44 PM
  #52
jeremyhughes's Avatar
Thanks deschlong and tlarimer I appreciate you guys, went to the junk yard today and got the parts for this chime mod! I'm excited!
jeremyhughes is offline
Old 03-16-2013, 04:44 PM
  #53
angrysmileyface's Avatar
Just make sure you put your wires in the right slots. I made an error and had to recheck my work originally, now it works beautifully. You may also want to check the insides of whatever ICU you purchased and check the capacitors.
angrysmileyface is offline
Old 03-16-2013, 07:26 PM
  #54
Looks like I'll be hitting up my local junk yard next weekend to do this mod. Thanks!
Krylon360 is offline
Old 03-17-2013, 03:34 PM
  #55
Worked like a chime! I did notice the chime needs to be mounted so its little notes can resonate properly, where did you mount yours?
Old 03-17-2013, 03:38 PM
  #56
deschlong's Avatar
I put it on the bolt that mounts the fuse box up.
Old 03-17-2013, 03:40 PM
  #57
Just curious.. what all is the INTEGRATED CONTROL MODULE responsible for?
Old 03-17-2013, 03:48 PM
  #58
forgive me for not searching first... It would seem the ICU does quite a bit of things.
Old 03-19-2013, 10:47 AM
  #59
LTHLINTGRA's Avatar
great write up!
LTHLINTGRA is offline
Old 04-11-2013, 11:39 AM
  #60
jahong16's Avatar
Great write up. Just finished my installation. Removing the chime took longer than I expected.
jahong16 is offline
Old 04-11-2013, 11:42 AM
  #61
deschlong's Avatar
^ Awesome!
Old 06-18-2013, 03:06 PM
  #62
Deschlong, I'm having some trouble with mine. I have a '95 DX sedan. I triple checked my wiring and for some reason I don't hear the chime. I don't even hear the door chime that has always been there when I open the door. The wipers work fine, so does everything else. When I put my negative battery cable back on, it beeped 6-8 times, and now it doesn't at all.
Edit: I don't think the beeping is from the chime. It's either from the ICU or the alarm, I'm not sure.
Sedanfan is offline
Old 06-18-2013, 03:18 PM
  #63
deschlong's Avatar
If you don't hear the key-in chime either then you've mucked something up. Take your mods off and put Humpty back together again, then try again.
Old 06-18-2013, 04:23 PM
  #64
Actually, everything works now all of a sudden. Now it beeps randomly even when the car is completely off.
Thanks for the help by the way.
Sedanfan is offline
Old 06-18-2013, 07:52 PM
  #65
SozeHuck's Avatar
Man, this is gonna be a lifesaver. I have now successfully killed my battery 5 times in 4 months due to leaving lights on and no chime. I'm headed to grab parts for this tomorrow. Thanks a ton.
SozeHuck is offline
Old 06-19-2013, 03:10 PM
  #66
SozeHuck's Avatar
Hey,a question, found all the pieces for this DIY but does $30 seem kind of a high price for an ICU? Are the wreckers out of their mind or am I just being cheap lol
Chime was only 8$ ...
SozeHuck is offline
Old 06-19-2013, 06:22 PM
  #67
It really depends on the yard, I believe its extremely expensive through a dealer. I picked up one for about 10$ at a pull apart and have 1 extra as a spare. Chimes can come from 90-93 Accords as well.
Old 06-19-2013, 06:49 PM
  #68
SozeHuck's Avatar
hmmm fair enough. I got the chime so maybe I'll just suck it up and drop the $30, 2 other scammer yards already tried to charge me $40, I'm doing the retrofit for the cabin air filter too and the girl quoted me out $8 for the Evap/heat duct lol so maybe that balances The bite out. So many parts, such limited income lol
SozeHuck is offline
Old 06-19-2013, 06:53 PM
  #69
deschlong's Avatar
Jesus ... mine usually cost in the $2 to $10 range. Although, first one I pulled was more since it was from a full service yard. Didn't make that mistake twice.
Old 06-20-2013, 01:43 AM
  #70
SozeHuck's Avatar
I wish, wreckers are gougers here, I pulled it myself then found out it they wanted 30$, I said I'll think about it lol. The other guys said only way they would do it for as cheap as $40 was if I pulled it.
I even tried a Craigslist guy and he wouldn't do it for $30 with me coming over to pull it. Lol easiest pull ever...
They told me a hundred pulled at one place. !!!
Ill prob end up going back to get the one I pulled for $30 unless the ICU gods favor me tomorrow
Edit: just ended up forking over the cash, I want to install this thing tomorrrow hopefully. Hopefully the ICU is in good shape.
SozeHuck is offline
Old 10-02-2013, 10:28 AM
  #71
BiggieBert's Avatar
^^ LOL, no. Go back and triple check your wiring, man.
EDIT: Look at the wiring diagram a few posts up. You have probably swapped the BLU/WHT wires. I told you not to do that!
So, if you swap the two blu/wht ( I know, I know, you told us not to), the wipers will be on even when switched off?
BiggieBert is online now
Old 10-02-2013, 11:01 AM
  #72
deschlong's Avatar
^ Yeah, seems like the other BLU/WHT has something to do with intermittent wipers. Why do you ask -- are you having a - *ahem* - problem? C'mon, 'fess up if you are.
Old 10-02-2013, 11:28 AM
  #73
BiggieBert's Avatar
Lol, yea I'm having a problem... When the car is running, my wipers are on intermittent, even though the switch is at the off position. When I de-pinned the civic plug I didn't read the "don't mix up the blu/wht wires" until it was to late... It was dark I swear!
Old 11-16-2013, 08:19 AM
  #74
I am assuming you corrected the mix up and it is working perfectly now?
Old 11-30-2013, 01:17 PM
  #75
13BT's Avatar
CHIME ON!
Just finished this retrofit about an hour ago! Everything works just as advertised! Thanks to Deschlong and rickkane.
Here is a video of what it should sound like when working properly.
13BT is offline
Quick Reply: [DIY] OEM 92-95 Honda Civic Lights-On Chime Retrofit (no RadioShack crap here, folks)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
