[96 civic ex] paint by door chippage?
hello once again
i have attached a picture of the chipping which is circled in red...
the paint on both sides of the car is flaking off... has this happened to anybody else?
i have a can of flat black paint, but it needs to be applied with a fine paint brush...
do you think i can sand the rest of the paint off and just go over it after i mask off the window / door?
thanks
ek
thanks
ek
Re: [96 civic ex] paint by door chippage? (ekcivic9)
You can sand and paint, or get a replacement.
If you do sand and paint, you have to get everything down to the chrome, or it will crack and flake from underneath your new coat of paint.
Re: [96 civic ex] paint by door chippage? (AutoXer)
Is it okay to just wipe all of the chipping stuff off, or do you have to repaint? I've noticed that lately also, especially on my passenger side. Haven't noticed any rust or anything?
do you think the whole paintbrush idea is bad? this stuff is like rustoleum in a can, but i cant spray it.
im just gunna sand off what i have now... and repaint over it. ill post pics when im done
Re: (j_wod2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_wod2000 »</TD></TR><TR><TD CLASS="quote">just tape that **** off use newspapers or bags tape them around your car so you dont get overspray anywhere and go to town </TD></TR></TABLE>
Take the trim pieces off completly, don't mask anything. They won't rust cause they're aluminum. When you're done painting, they won't match the other trim pieces, so if you care about it enough you should paint them all at the same time.
Re: (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">oh just get a new door....</TD></TR></TABLE>
O_O???
Anyways. There has to be something better than flat black paint to replicate that **** that is coated on there. From past experience ive noticed that flat black paint tends to have areal dull look. So it wont look right I bet...
Maybe that one **** will work... You know that black **** you put on a truck bed?
O_O???
Re: (Plugg'd)
Go to your nearest dupont/ppg/martin senior paint distributor
and ask for a pint-quart of bumper coating (black) or trim paint.
Good stuff. Coated mine 2 yrs ago. No fading, no chipping.
Re: (EKFerioHawaii)
aw ****. i didn't kno there was such a thing. How does this bumper coating stuff look? Do you have pics? I want to take my sideskirts back to the stock look but flat black aint crackin
hey, I had the sme problem you didthe dealer wanted $120 for them both...... h
I jsut took a razor blade to the flakes and stripped the rest of the rubber with the razor blade. the coating on those is a thick rubber. As far as sanding, just think how fun it would be to sand rubber.
After i scraped all the black off to make it all chrome. I put 3m electrical tape on it and it looks OEM..
TRY IT IT LOOKS REALLY GOOD AND COST NOTHING IF YOU HAVE A RAZOR BLADE AND TAPE.
i was reading all of this and nobody posted electrical tape until the end. it WORKS, and looks OEM, you can't even tell its tape. Try it, if you don't like it then take it off.
"Window molding eletrical tape mod" :-P
lol wouldnt the heat from the sun just cause the tape to go all yucky?
yeah at first i didnt believe that it was rubber, but you guys are right! damn its a pain in the ***.
Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">cyclone- is it possible to remove those pieces? i dont think they are going to come off.</TD></TR></TABLE>
I know they come off... I just don't know if they'll go back on...
They're held on by plastic (maybe metal?) clips that'll probably break when you take them off, but as we all know it's usually the part that the clip attaches to on the piece that you're removing that breaks. I got mine off my sedan without any issues, but I may have been lucky, I don't know.
Re: [96 civic ex] paint by door chippage? (Maness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maness »</TD></TR><TR><TD CLASS="quote"> Is it okay to just leave it at the metal? I know it looks like *** but I'm curious =D</TD></TR></TABLE>
it'll oxidate unless u seal it with something
If you want it I suggest that instead of flat black. (SATIN black) Its flat but it still have a little shine to it. and its darker. $2.59 at you local harware store. big can. trust me its what you need. at least check it out
Re: [96 civic ex] paint by door chippage? (MidwestSi)
a diy for that??
just take off the pillar thingy that is on the side of the door and then pull it off. there are white clips that hold it in place so you have to push the black piece around to unclip it, but in most cases the clips will just snap.
cdplayerto
Honda CR-V & Element
11
10-13-2016 06:24 PM
1hotcivicSi
04-25-2004 07:39 PM
