*HELP* any familiar with the tekniqauto snap off system?
I'm having trouble getting my horn to fit on there with the current setup
its a MOMO hub and street snap off system and a momo race steering wheel
I got the quick release to work, but with the current set of parts, I can't get the horn to go on!
I have the momo adapter kit from tekniqauto also
i have the same problem. i think there are two things you can do.
1. buy a momo, sparco, or srr spacer. put this spacer between the wheel and the snap off part that bolts onto the wheel.
2. buy that momo f1 concept horn plate. that uses wires, so it will fit.
the reason the momo button horn does not fit is because the connector posts are too long
Re: (cxSOHChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSOHChatch »</TD></TR><TR><TD CLASS="quote">i have the same problem. i think there are two things you can do.
the reason the momo button horn does not fit is because the connector posts are too long</TD></TR></TABLE>
thanks, i realize i need the tekniqauto hub because i don't want to add another spacer, which would make it even closer to me
MASTRCHANN
08-23-2005 04:26 PM
