**Vibration on steering wheel/rear view on EM1**
Okay so i was on a the interstate the other day coming home from relatives place..i notice that as soon as the car heats up i notice vibration from the steering wheel and my rear view... it's really bad...and when i let go of gas and coast it stops doing it....the only thing i've done was got prothane motor mount inserts installed like 2 years ago......never had the problem till now...withing the past two-three months it was doing the same but not as bad....any ides...help me out guys...thanks
Re: **Vibration on steering wheel/rear view on EM1**
well within the past two months i got my front tires aligned...i didn't do the back but i'm sure the back wouldn't make that much vibration....maybe ill just bring in the car and get all four wheels aligned again....huh...dam it....hate it too...other thing is too..if it's the wheels..wouldn't it happen right away instead of untill the car heats up....
make sure all the motor mount bolts are tight and check the spark plugs for fouling.
Maybe even a compression test cold then again warm.
Cool Cool Island Breezes. BOY-EE
How do you align the front without aligning the back? The front is aligned based on the rear alignment.
Anyway...an alignment doesn't cause a shake. A balance issue might. People get alignments and balancing confused for some reason.
It's weird that it only happens when the car warms up. Maybe you have a misfire or something. Do you have a check engine light?
i have the same thing and mine was the axles if you have a swap make sure the axles are correct ones needed also balance the wheels or replace tires, front end alignment, tie rod ends such things will cause shakiness in steering...make sure all lug nuts are tight
can anyone explain to me how a "front end alignment" is done on a car with 4 wheel independent suspension? Also how does an alignment make the car shake?
does the motor feel like its running like **** and causing it to shake?
If your car is lowered, it causes camber wear which can result in bubbling of your tires. check the fronts if thats where the shake feels like its coming from
okay..finally...no check engine light or nothing when it does it..did just change my driver side axle within the past month.... passenger is still good not ripped...all lug nuts are tight..otherwise would make noise when rolling...like i said..only does it on highway and a tab bit in the city...but as soon as i let go of the gas it stops doing it.......only when i'm cruising or giving it gas....please help guys...
what i meant was that i got my front tires balanced...but early this year i had my car aligned by a friend from school..and he says everything is in the green zone...
You mean toe wear and cupping. Toe wear causes cupping, blown shocks also can cause cupping. Camber really isn't a major wearing angle of tires....and I'd be hard pressed to believe that camber could cause cupping.
well if my tires where cupping or whatever....wouldn't it happen right away instead of only when the car warms up...????
check the driver side motor mount i think they are still oil filled that year, may be wrong,
if its bad you most likely see oil every where around the mount. my buddys broke and the whole shook.
well..i got non broken OEM mounts and i got Prothane motor mounts inserts...so i don't believe it's the that.......like i said...only does when the car warms up.....
i had the same problem with vibrations during acceleration......i found that the axle was the problem....although the boot isn't ripped, it can still be damaged internally....it's the inner section of the axle that was bad (where it connects to the half shaft on my teg on the driver side)...so don't eliminate that being a problem just from looking at whether it's torn or not.
92ehatch
11-27-2005 01:53 PM
yohan
03-19-2005 10:19 AM
jerm001
16
03-04-2005 09:21 AM
