**Throttle Cable/Bracket Question**
Hey everyone. I just wanted to try and clear some things up that I am unsure about. I have a 1993 delSol that I have swapped a B16A into. Since I have done the swap I been using a "rigged bracket" and the stock Z6 cable. As far as I know the swap has a TypeR intake manifold. So from that I am assuming I need the TypeR cable bracket. But my question is what cable to use. I have been reading around and seen things such as; (94-01 Integra) (94-97 VTEC delSol) (TypeR). My goal of this is to make it right and not have it "rigged". So if anyone has an idea or can help me out that would be greatly appreciated.
Here are a few links I found:
The link in red is a cool link I found that has stuff for swaps. It has the bracket and a selection of cables.
-http://hondaswap.com/civic-del-sol-eg-ek/b16a-swap-problem-throttle-cable-503173/
-http://www.swapshopracing.com/contents/en-us/d874.html
-https://honda-tech.com/forums/showthread.php?t=3030991
-https://www.flatironstuning.com/p-1525-oem-acura-integra-type-r-throttle-cable-and-bracket.aspx
OEM Part Numbers:
TypeR Bracket: 16411-P73-000
TypeR Cable: 17910-ST7-R01
94-97 delSol VTEC Cable: 17910-SR3-L01
OEM Part Numbers:
mouab18c1
20
07-09-2013 11:36 PM
Crank
11-07-2008 02:30 PM
