**Lug not help!!**
**Lug not help!!**
I've decided to switch out my broken wheel studs off of my 95 eg and replaced them with arp extended wheel studs but the thread pattern for the arp studs are m12x2.85. I can't find any lug nuts that fit that pattern online. Anyone know of any lug nuts that fit this pattern?
Re: **Lug not help!!**
That number makes no sense. M12 means the bolt is 12 mm in diameter, but the thread pitch will be either 1.25 or 1.5 (mm per thread). Take one of your studs to a parts store and try nuts on it. The part of the nut that touches the wheel also has to match the kind of wheel that you have. If it's an aftermarket wheel, the wheel manufacturer should be consulted.
