Question between Si and Vx hatchback
I want to know about two of vehicles. Does Si hatchback comes with sunroof in only model? What about VX?
Re: Question between Si and Vx hatchback (batallic)
Yeah I know ex model come with sunroof. The reason why I ask this question is because I purchased a shell hatchback that displayed VX model but it come with sunroof! I had checked vin number and it shows that it has a Vx model...Is there any other way I can check if my hatchback is Si or VX?
Former Moderator
Re: Question between Si and Vx hatchback (94EG8)
Easiest way to tell the Si chassis from VX chassis is the VIN number:
Si = 2HGEH3... for the VIN (only Si has the EH3 designation)
VX = 2HGEH2... for the VIN (as does the CX and DX as well)
Aside from that I could go on listing the model differences between the two such as:
Si has rear discs - VX has drums
Si had FACTORY power sliding moonroof - VX did not
Si had power mirrors - VX did not
Si had two mirrors - VX did not from the assembly line (though dealers installed many)
Si had cruise control - VX did not
Si had rear washer/wiper - VX did not
Si had clock - VX did not
Need I go on?
I say someone had an aftermarket roof installed on that VX.
Need I go on?
ditto....pics would help. cx and vx = no side moldings. dx and si, but si has sunroof. the information b18c5-eh2 just gave you should already be enough for you not to take out the headliner. and you could check out the interior patterns.
H-T White Ops
Re: Question between Si and Vx hatchback (dutchman5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dutchman5 »</TD></TR><TR><TD CLASS="quote">I ll take headliner out and check if it s come with stock or weld sunroof...
thanks </TD></TR></TABLE>
No need to even remove the headliner.
Just open the moonroof.
Is the rubber seal on the glass or on the roof? If it's on the roof, it's aftermarket.
Re: Question between Si and Vx hatchback (NOFX)
Si has rear discs - VX has drums-- yes i got drum
Si had FACTORY power sliding moonroof - VX did not- yes it had sunroof but look extacly like stock!
Si had power mirrors - VX did not .... yes i had power mirror on both side
Si had cruise control - VX did not... dont know about cruise.
Si had rear washer/wiper - VX did not .... not sure
Si had clock - VX did not... not sure
I think u guys right..someone could be weld stock sunroof on it.. i ll take picture tonight .
Modified by dutchman5 at 6:37 PM 9/24/2008
Dead CIVIC
15
03-05-2011 04:26 AM
halfkoreanboy
28
03-22-2009 10:44 AM
