***Car is bogging when I press on gas!!!!*** Help
Doesn't want to go at all when I accelerate. Seems like its not getting enough fuel. Its a B18b, it has a edelbrock intake manifold with 70mm throttle body. Would that make it bog like this? It has stock everything else except for the intake manifold. this is my buddies car btw.
Re: ***Car is bogging when I press on gas!!!!*** Help
thats a big *** throttle body for a stock car.
check the fuel system could need a new filter
also check plugs and wires.
any cels?
any cels?
Plugs and wires are good, new distributor, there were cels but didnt get a chance to look at em yet, ya sounds bad, but i forget what it was before but didnt seem like it would make this problem, trying to stepside the cel, just wondering what could cause the problem
Does it always bog? Or if you let off the gas a little it stops doing it, that could possibly be fuel injectors and they just need to be cleaned, or even bad wiring somewhere. Friends car bogged after his motor swap, and something wasnt plugged in and thats why it bogged
1) Pull the CEL codes. This is not something to sidestep.
2) Check the mechanical timing of the cam and crank and the ignition timing with a timing gun.
lopezchris21
15
06-13-2012 12:25 PM
