*** broken temp EG switch.. how to fix/replace it?
well my car came with a broken EG climate TEMP control. I can't move it from hot to cold right now.
anyone know ho to replace it?
-is it just a simple clip on "switch" arm that i snap into place or do i need to take it apart inside?
I have an extra JDM cluster too so i might beable to use some parts off of that.
Re: *** broken temp EG switch.. how to fix/replace it? (Charlie Moua)
well, your gonna have to pull out the climate control unit to fix it anyway so get going on that. Inder it, the arm that controls the cold/warm connects to a point on the bottem... There is a white plastic clip there... If tht looks in goog, make sure that the connection under the glove box (Where the wire runs down to) on on. Maybe it's not even attached, and that's why you can't change the temp.
Hope that helps
Hope that helps
Re: *** broken temp EG switch.. how to fix/replace it? (civiksiracer1)
is the arms that though ***** go on broken to where the ***** wont click in place?? If so then check under and behind the climate control to make sure everything is in place. Also, make sure that the wire that go to the black arm is still in place because if it aint then the switch will move freely but if its not pullin on the wire then your not adjusting your temp.
