Del Sol Passenger Window Problem
Old 08-21-2011, 10:27 AM
kryptekz's Avatar
Default Del Sol Passenger Window Problem
93 Del Sol
The Driver side and rear window work fine.
The passenger windows likes to randomly work. It is not b/c of the window lock button either.
When the window does work, only the switch on the drivers side can roll it down, otherwise the switch on the passenger side is completely dead. I decided to disconnect the switch on the passenger side to see if it changed anything. It would still randomly stop working.
So, could it be the main Power Window Switch on the driver side? Can a faulty driver side switch affect the passenger side regulators function?
It's not the passenger windows motor since it rolls the window up fine and doesn't stutter, or appears to be weak.
I rather not bring this to the dealer, since I think it might be a simple fix. I did replace the fuses and that did not fix the problem either.
Thanks
Old 08-21-2011, 10:47 AM
strategy400's Avatar
Default Re: Del Sol Passenger Window Problem
It could still be the motor.
Old 08-21-2011, 10:49 AM
kryptekz's Avatar
hmmm, maybe I should just bring it to the dealer.
Old 08-21-2011, 11:05 AM
Former User's Avatar
Test the passenger side switches.
Old 08-21-2011, 11:10 AM
kryptekz's Avatar
The passenger side switch is not working at all. Even when the power window randomly works, i can only use the main driver side switch to roll it down.
Old 08-21-2011, 01:26 PM
natetheninja
09-12-2009 08:46 PM
94_DC
08-31-2009 11:38 AM
del_sol 2009
11
04-21-2009 01:55 PM
Eg2Love
10-08-2008 05:19 PM
deconstruct
04-12-2005 08:43 PM
Quick Reply: Del Sol Passenger Window Problem
