****would a bad cam seal.....****
would a bad cam seal make you lose power?
it seems like i have some antifreeze leaking from it, im not sure if its the headgasket .... i definitly have a slight loss of power, it sounds somewhat more throaty and different when i hit the gas.
my gas mileage is pretty crappy too....
thanks alot
thanks alot
Re: ****would a bad cam seal.....**** (sirhatchalot5)
antifreeze won't leak from the cams, it will leak from the block or a hose. If it comes from the block, or I should clarify (where the head meets the block) you most likely need a head gasket.
BigDare23
13
10-15-2010 03:02 PM
