*****Need headlight help ASAP!!!!! ******
So i was putting side markers in the other day and just got them up and running i was messing with my headlights last night and now only the driver side headlight works..But its kinda funny that the passinger side headlight comes on when i click the high beams..I put in my denjis and only the highbeam worked with them aswell.. I went and got a new plug thinking it might be the plug..But it still dosnt work im stumped...
I NEED HELP ASAP this is my DD..
Thanks honda-tech, help me out
-NICK
-NICK
Re: *****Need headlight help ASAP!!!!! ******
i was changeing them out.. and i got to the passinger side and now only the highbeam works..i have no lowbeam..I have traced the iwres back to where they start to see if there was a break in the wire and there isnt..IDK what todo know..
HELP!!!!
HELP!!!!
What fuse would it be and is it under the hood or by the knee panel on the drivers side, And wouldnt the fuse effect both headlights low beams..
I should also mention the the Denjis i was putting in have HID low's which shouldnt matter because the driverside still operates..
I know that there is two seperate fuses for high beams in the inside fusebox. Not to sure with denjis, you might check the ground for the HID kit?
Well i checked the fueses and none are blown..As far as the denjis it dosnt matter they are just serperates high and lows..The hids are grounded right becasue the driverside is working fine..
The bulbs are still good in both because i just checked that aswell only the high beam works on the passinger side..
IM stumped...
IM stumped...
if they are hid's maybe the ballast blew. get a test light or a volt meter and see if u have volatage to the connecter where it plugs into the bulb.
Hids are fine and my stock headlights are fine..the reason i say this is because i plugged in my stock headlights and Denjis to the driverside plug ( the one that is working)..
Im still stumped i went to NAPA and got a new h4 plug and the low beam still dosnt work..
Anyone got anything that i can try..
Thanks, NICK
Thanks, NICK
Well i went to Napa again and spent 20$ in fuses and under the the hood fuses and replaced them all and i apperintly fixed the problem I didnt notice any blown fuses the first time and still cant find what or where the problem was..
But all i know is that it is fixed..Thanks for all the help and imput guys..
This is why i love HONDA-Tech
-NICK
-NICK
try smacking the headlight the doesn't work. Mine's acting up lately and i dont know whats with it but if I smack it, it goes
Thats what i figured but..its all good now.. you really dont realize what 20$ in fuses amounts too!! ALOT
But thanks for the help guys..
be4unvme
22
07-02-2012 10:52 AM
