**********EG dash and tail lights????**********
Old 10-31-2007, 07:56 AM
22's and Man Boobs's Avatar
Default **********EG dash and tail lights????**********
On my way home last night my dash lights went out in my 95 ex coupe, a couple minutes later Mr. popo pulled me over and told me that I had no tail lights, my brake lights work, just not on the dim setting when the headlights are on... I haven't checked any fuses yet, but would the problem be fuses or are the wires shorting out. Are the even on the same circuit. Another thing is that the climate control and blower don't work, the lights on the control don't come on and the blower does not work either... I thank you guys ahead of time
Old 10-31-2007, 08:01 AM
lluks_844's Avatar
Default Re: **********EG dash and tail lights????********** (22's and Man *****)
probaly the 10a fuse, mine have blown before, theyre all wired to that fuse so it should be easy, if u dont have the cover i believe its the seventh one up on the left side right after the 7,5a fuse
Old 10-31-2007, 08:04 AM
instructor74's Avatar
Sounds like a blown fuse. check them all. Are you running an after market sterio? Pull it out and make sure the wire for the illumination/dimmer is hooked up if it isn't being used cap the end to keep it from grounding out. If it grounds out it blows the fuse for the dash lights and the rear tail lights.
Old 10-31-2007, 08:51 AM
Default Re: **********EG dash and tail lights????********** (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a blown fuse. check them all. Are you running an after market sterio? Pull it out and make sure the wire for the illumination/dimmer is hooked up if it isn't being used cap the end to keep it from grounding out. If it grounds out it blows the fuse for the dash lights and the rear tail lights.</TD></TR></TABLE>
Yes it has an aftermarket stereo... I just bought the car on saturday, so I'll check the fuses and the wires... Thanks guys
Old 10-31-2007, 08:54 AM
jdm91CrxSi's Avatar
its the fuse right under the two 10a l low and high beam headlights. it happend to me before. just replace it.
Old 10-31-2007, 12:56 PM
Default Re: **********EG dash and tail lights????********** (jdm91CrxSi)
Thanks guys, I got them to work
slammed em1
01-23-2010 09:26 PM
95silverteg
09-30-2008 04:48 AM
peachykeenwight
04-12-2007 04:52 PM
KaoticSnow
01-25-2007 09:52 AM
xxx
10-31-2005 06:57 PM
Quick Reply: **********EG dash and tail lights????**********
