Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
5W20 vs 0W20
Old 12-13-2012, 06:28 AM
oscar2011's Avatar
Default 5W20 vs 0W20
I always do my oil changes with 5W20 as required, my question
is : does anybody use 0W20 intead?
Old 12-13-2012, 07:15 AM
SirProject's Avatar
Default Re: 5W20 vs 0W20
i would stay with 5w20. only difference is the winter rating so the 5w20 is thicker during the cold. so only startups and what not. besides that when they are both warm they are both 20 weight
Old 12-13-2012, 08:07 AM
Steve@Spreen's Avatar
This, without knowing your mileage, driving style/habits and geographical location, stick with the recommend oil.
Old 12-13-2012, 09:16 AM
oscar2011's Avatar
Temp here in the winter can be around -4.... F to -22 F and colder , yesterday it was -24 F.....Regina , Canada. I was thinking i could benefit in the wint er changing to 0w20 without damage to the engine...civic has 65000 miles, always use syntec
Old 12-13-2012, 08:21 PM
av911's Avatar
Old 12-14-2012, 06:51 AM
DaveSi677's Avatar
That graph is wrong cause the 02-05 Civic Si started using 5w20 but then switched to the 5w30 due to galling on the cams
Old 12-14-2012, 07:19 AM
In that case, there will be no harm in using the 0w-20, I would myself. I also am a fan of full synthetics, but that's another whole different discussion
Old 12-15-2012, 02:21 PM
oscar2011's Avatar
Thank you guys for your replies, I use mobil 1 synthetic and will try 0W20
Old 12-15-2012, 02:38 PM
Lambo123's Avatar
I've always said if you live in a place where it gets cold then 0w20 (or whatever oil weight your running) is always better than 5w or 10w. There are absolutely no negatives. You want the oil to start thinning as fast as possible once the motor is turned over. Remember, most engine wear occurs during startup.
islnder102
10-12-2006 06:45 AM
Syndacate
01-19-2006 05:31 AM
LOwrestling2001
11
08-26-2002 09:00 PM
far
05-12-2002 12:41 AM
f1nal zeros
04-16-2002 09:05 PM
Quick Reply: 5W20 vs 0W20
