My new 07 Si - Upgrade options?
I'm not new to the forums but new to this section. So I got a 07 si. I sold my 95 integera, which was beat to sh*t. Now I want to do some modifications to my si. What are some things I can do to it performance and look wise that won't break my wallet?
Re: My new 07 Si - Upgrade options?
If your wallet is $4,000 you can supercharge it to 300whp.
Rather not lol. I was thinking bolt ons? Lol. Recommended ones?
Best bang for the buck= Header+hi-flow cat+catback+cold-air intake+tune
Hondata Flashpro is the best $600 you can spend on the 8th gen Si.
Originally Posted by CKnight90
(Post 50771736)
Alright thanks.
Alright thanks. Flashpro for 600? When I looked they were around 800. Also does a flashpro always have to be hooked up?
(Post 50777822)
Originally Posted by foumer
(Post 50774353)
Best bang for the buck= Header+ NO cat+catback+cold-air intake+tune
and used flash pros go for $400-500, and a tune is like $200. Buy all at once so you're not spending money on tunes every 6 months. |
Ok. Can you directly to the site that sells them for $400-500?
(Post 50779834)
Originally Posted by vtecnique69
(Post 50779332)
fixed for accuracy lol
You can find flashpro easily for 550$ used... just make sure it's unlocked before purchasing it.
It will be the best $$$ you spend on the 8th Si trust me! |
Replace all maintenance items before you purchase performance parts.
.02 |
Originally Posted by Ohmega
(Post 50784434)
.02 |
Suspension components, gaskets, ignition components, timing components, etc.
Bring the car back to its original glory, then modify it. |
is it in good running condition ?
as an 07 it probably needs some loving before you modify it whats the mileage ? |
(Post 50788181)
Originally Posted by cptcljerjr
(Post 50790912)
as an 07 it probably needs some loving before you modify it whats the mileage ? It has 145k miles. I have a chance to buy a Hondata Flash Pro for $350 used. When/if I get it what would be the next step? Since I keep getting the Lean CEL. |
(Post 50806381)
What gaskets? Seems like everything is fine right now. What are signs stuff needs to be replaced?
yes. It gets around 25mpg right now in town. Not sure about highway. It has 145k miles. I have a chance to buy a Hondata Flash Pro for $350 used. When/if I get it what would be the next step? Since I keep getting the Lean CEL. What brand is the CAI? |
(Post 50806381)
(Post 50806381)
The tunes that are available for free are all race tunes which are terrible cals for you car. They will cause issues with your fuel thank shrinking and causing evap issue also when you open your gas tank it will sound like a Pepsi can. Getting a proper tune from VitViper will get you a Hybrid tune and that is what you want. You want to make power and the car running smooth speak to VitViper. |
When I had my 07 Si, the best things I bought for the car were an exhaust, header, intake and flashpro. I'd honestly start there.
If it were my recommendation, I'd start in this order: Intake Exhaust Header + Flashpro |
Depending on which Intake you go with you will need Flashpro to make AFR adjustments due to running to lean!
I would do Flashpro first... its a night and day difference! |
