Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda Civic 08 A/C compressor shut off
Old 06-07-2019, 03:01 PM
Default Honda Civic 08 A/C compressor shut off
My A/C will turn on at idle, but as soon as I rev the engine above 1700 rpms it shuts off and doesn’t come back on. I had the freon replaced. They assured me there were no leaks or air pockets. What are my next steps?
Jake Hounshell is offline
Old 06-07-2019, 08:54 PM
Default Re: Honda Civic 08 A/C compressor shut off
Worn out A/C clutch or bad thermal sensor... common failures on the "K" series A/C compressors.
JRCivic1 is offline
Old 06-08-2019, 12:02 PM
Are are you talking about the AC Clutch Compressor Relay, or something else?
Old 06-08-2019, 01:17 PM
Chrisfrom1986's Avatar
Most of these cars came with the trash R18 engine, just fyi.
Chrisfrom1986 is offline
Old 06-08-2019, 08:31 PM
True dat.
OP, it is not going to be something simple and cheap like an A/C relay. There is a slim possibility that your system is overcharged and your line pressures get too high off idle and thus, the system shuts down. I still think the logical problem is that the A/C compressor clutch itself is worn and slipping under load.
JRCivic1 is offline
Old 06-09-2019, 06:28 PM
jokerstone's Avatar
How much is the ac compressor clutch part?
jokerstone is offline
Old 06-10-2019, 01:06 AM
K5^
Brand New
K5^'s Avatar
Icon3 Re: Honda Civic 08 A/C compressor shut off
True dat.
Wouldn't hurt to try replacing the relay. Simple $7 part, but I do agree it is likely the compressor clutch. Ran into the same problem recently.
Depending on what model you have:
R18 Part # 38900-RNC-Z51 approx $250
K20 Part # 38900-RRF-Z51 approx $183
(Prices courtesy of majestic honda )
K5^ is offline
  • Ask a Question
Question Title:
Description:
