Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
blinking check engine
Old 10-04-2012, 03:05 AM
adueisaac's Avatar
Icon6 blinking check engine
Please i have my 2006 model honda civic check engine blinking, whenever it happens like that the car doesn't pull well at all. and my ignetion coil keep on going bad frequesntly, what might cause this to happen? i need help. thank you
Old 10-04-2012, 07:52 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: blinking check engine
If its a 2006 pull the code with a scanner and post it
Old 10-14-2012, 09:03 AM
Preston Pierson's Avatar
Blinking MIL is a severe misfire which would also be why your car runs poorly when it's happening. Pull the codes as said and see if it's one cylinder or which ones specifically. Is your car stock or modified...and are you replacing parts with OEM or generic?
Old 10-21-2012, 04:24 PM
Zebra's Avatar
A misfire can eventually ruin the catalytic convertor - it needs immediate repair.
Old 10-24-2012, 09:12 AM
Auto 360's Avatar
You should take it to your nearest mechanic and have him take a look at it, especially if its a misfire.
Old 10-30-2012, 05:48 AM
TheMightySi's Avatar
Overwhelming details on trim/engine/mods for this 2006 civic, either way you have to get your vehicle scanned for trouble codes and go from there.
Old 10-30-2012, 06:45 AM
WhiteNeko's Avatar
I wouldn't drive it if possible. Damage may be minor now, but will cause severe damage if you keep driving it with a misfire.
Old 10-30-2012, 07:51 AM
SiRCiviC94's Avatar
happen after a rain storm? check out the ecu and reset
STR8__
K Series
03-07-2017 08:20 AM
cennouu
01-12-2011 07:49 PM
Untengijutsu
09-27-2007 11:20 AM
Quick Reply: blinking check engine
