The biggest OEM Honda brake upgrade ever - Custom mounted Acura RL calipers
#51
Re: (Demonis)
Not yet but I have an update.
I am now offering the necessary hub rings for the 12.6" rotor over the civic's smaller 5x114.3 hub (the RL hub is 5x120 and larger in center bore.
#53
Re: (civic710)
No those rotors are proving more trouble than they're worth. I was hoping to use it for its hub-centricness, but the brackets would have to be modified even worse to the point where the knuckle tabs or the caliper itself would be have to be modified, so its not exactly a bolt on kit. for the extra .3", its worth doing it safer.
#55
Re: (BrakeExpert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">I am using a block of hot rolled carbon steel, commercial quality</TD></TR></TABLE>
I would be worried about this rusting. Any steel (except stainless of course) is going to rust, but HR carbon steel is one of the quickest to do this (rust). Have you looked at using aluminum or stainless instead?
#56
Re: (chiggin)
Well yes that is an issue, but of course these can be painted (or coated) to remove the external rust factor. I have looked at aluminum, but the factor for me was safety, and I didn't want to use aluminum because no matter how you look at it, its 1/3 the weight of steel and 1/3 the strength. I'm using factory bolts to the knuckle which are still torqued down pretty heavy and its nice to be able to treat this bracket as a solid body. Stainless is just extra cost, and in all honestly, if unpainted, its only surface rust, so the only actual problem is cosmetic, I mean the brackets are a solid bar of steel, there not gonna break, hehe.
#58
Re: (BrakeExpert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">but of course these can be painted (or coated) to remove the external rust factor.</TD></TR></TABLE>
Of course....personally I would have them coated black. I don't think that I would like the 'rust look'.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">I didn't want to use aluminum because no matter how you look at it, its 1/3 the weight of steel and 1/3 the strength.</TD></TR></TABLE>
Not entirely true. 7075 Aircraft Quality Aluminum has a tensile strength of 77 (the greatest available in Aluminum bar) despite its light weight. This is comparable to the tensile strength of HR Carbon Steel which is an average of 58-80. The only problem would be the extra cost. 7075 Aluminum, along with Stainless, would be about $2-3 more per pound than the HR Carbon Steel. With this added cost, the least expensive route would be coated HR Carbon Steel. I just wanted to let you know that Aluminum could be an option. **correction: Stainless is $2-3 more than HR Carbon Steel. 7075 Aluminum is closer to $5-6 more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">and in all honestly, if unpainted, its only surface rust, so the only actual problem is cosmetic</TD></TR></TABLE>
Yes. But one thing I was wondering...could this surface rust flake off on to the disc or calipers and eventually and effect braking performance? (or even damage the disc?) I'm not sure if this would actually be an issue, but it is just something I thought of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">I mean the brackets are a solid bar of steel, there not gonna break, hehe.</TD></TR></TABLE>
lol....you're definitely right there. If you can break those pieces of steel without the help of a machine, the only thing you would have to worry about would be kryptonite.
Modified by chiggin at 1:31 PM 10/11/2007
#59
Re: (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis »</TD></TR><TR><TD CLASS="quote">whats the price difference for stainless vs paying extra to paint/powder coat.</TD></TR></TABLE>
Stainless will typically be $2-3 more per pound than HR Carbon Steel. For example...a piece of HR Carbon Steel measuring 1/2" x 4" would be about $0.79/lb. A piece of 304 Stainless (least expensive grade) measuring the same size would be about $3.98/lb.
I am not sure about the coating cost, but I don't think that it would be more than buying stainless.
#60
Re: (BrakeExpert)
BE, you popped into the Acura-Legend.com about this upgrade for the Second Generation Legends. We haven't heard back from you in a couple weeks, and there are those of us wanting to know if you have completed the retrofit for our cars?
Thanks!
Thanks!
#62
Re: (exhaust_note)
There is a full front setup for the 06 Si.
My apologies to those on acura-legend.com, sorry about the delay. I'm back and I will be on tonight to answer everyones questions.
#67
Re: (BrakeExpert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">There is a full front setup for the 06 Si.</TD></TR></TABLE>
Includes? for what price?
2 calipers
2 brackets
2 redrilled rotors
front pads
misc. lines
2 calipers
2 brackets
2 redrilled rotors
front pads
misc. lines
#69
Re: The biggest OEM Honda brake upgrade ever - Custom mounted Acura RL calipers (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">
So, for those with comprehension issues like me, this kit uses:
Acura RL calipers
Acura TL rotors (no redrilling necessary)
?</TD></TR></TABLE>
is this right. we can use the 12.3 TL rotors w/o redrilling.
Acura RL calipers
?</TD></TR></TABLE>
#71
I remembered seeing this a while ago. What ever happened with it? I now have the car and in need of an upgrade. It's between this or a wilwood setup more than likely.
Any info would be nice.
#73
holy old thread lol but i have this setup on my car:
RL Calipers; nissan 350Z brembo package sized rotors (12.8") ; oem si brake lines
the stopping power is great but it took alot of fabrication involed to get them to work right on the car. The spindle on our cars is different from other hondas as per what i found out but heres a pic. the stopping power is great FAR FROM A BOLT ON
#75
i was at Buttonwillow last year and there was a 07 si and a full race si and both had TL type S brakes
