08 SI
i just bought my SI about three weeks ago.. and just curious on what i could do to it to add a little hp/torque.. i want to eventually work my way up to a turbo.. but that will be later down the road.. just looking for some pointers right now..
Re: 08 SI
Budget? You could of course start with the basic i/h/e. I'm not familiar with NC laws regarding modifications and tests.
Re: 08 SI
depends on your budget and goals
Re: 08 SI
i have around 1200$ right now.. not much.. so i guess im looking to start small..
Re: 08 SI
Originally Posted by chewyv
(Post 47195649)
Re: 08 SI
with 1200 i/h/e is the way to go you should have enough give or take a 100 or 200
Re: 08 SI
what name brand do you recommend? im not in a HUGE rush to do anything.. so i can save a little more for a better name brand.. the name that ive heard alot among my friends is skunk2.. is that any good?
Re: 08 SI
If 1200 is your budget, I would recommend a PLM or skunk2 alpha header, flashpro, and an e-tune from e-tunez.
Price breakdown is as follows: - PLM/SKunk2 alpha: 400-450 - Flashpro: anywhere from 500-700 - e-tunez etune: 200 IMO, thatll give you the best bang for your buck. Prices depend on if you can find it used. Both of those headers have some issues that youll want to read up on. However, since you said you aren't in a rush, I would ultimately recommend that you do your own research and make up your own mind. Then, you have no one else to blame but yourself for the decisions that you make, and you'll actually know what you are getting into. |
Re: 08 SI
Originally Posted by HRsi-dan
(Post 47199152)
Re: 08 SI
I'm pretty new so I'd do some research to find out what they all do but yea skunk2 is a good way to go with exhaust. You can find the parts anywhere and it sounds great
Re: 08 SI
Skunk2 Alpha Header for like $500
Hondata Flashpro (check 8th gen, i was able to pick one up for $400) Id say CAI or SR or a used exhaust. You can do them yourself and a buddy and get the tune at a shop |
Re: 08 SI
what exactly is the hondata flashpro? cant find anything explaining what it does
Re: 08 SI
Originally Posted by Pj_SI
(Post 47209536)
Re: 08 SI
(Post 47199219)
could you explain what these things do?
In simple terms they remap your ecu, they can change fuel trims, when vtec kicks in (if equipped) throttle response etc, depends on the tune. Some are piggy backed off the current ecu with a harness. Basic tune things, headers, many options out there, exhaust many options. I do not recommend getting rid of the cat converter, some may tell you to I would not. |
Re: 08 SI
Ever heard of google.com? Try starting there.
Re: 08 SI
Originally Posted by motegicivic
(Post 47210503)
