Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
CASTER PULLING RIGHT..COMMON ISSUES?
Old 05-04-2012, 07:22 AM
TwotoneC1Da9's Avatar
Default CASTER PULLING RIGHT..COMMON ISSUES?
Whats up h-t just getting used to my fg2 and recently learned about us not having adjustable caster...Got it aligned and everything is in spec but it still pulls hard to the right. I've searched but only came up with the general conclusion that damage must've been caused from a pothole etc... anyone pin point an issue with this? control arm, bent tie rod?...thanks in advance.
Old 05-04-2012, 05:35 PM
Default Re: CASTER PULLING RIGHT..COMMON ISSUES?
Old 05-05-2012, 06:06 PM
Turtle_FA5's Avatar
id like to know, im tucking tire and got alignment and still pulls to the right
Old 05-09-2012, 08:01 AM
wish someone had an idea, honda tech really coming thru...
Old 05-09-2012, 11:20 AM
been there done that
doood's Avatar
Why don't you get under there and look for loose, bent, or broken parts? We can't diagnose everything through a computer screen.
Old 05-09-2012, 12:07 PM
I did my dood, felt for side to side and top and bottom movement and compared lca's and te's on each side nothings popping out at me..
spotrep
Suspension & Brakes
07-08-2013 04:28 PM
tatmark1
06-21-2011 07:21 PM
ekhatchey
06-05-2011 07:37 PM
el_gzman
Suspension & Brakes
06-09-2007 10:46 AM
SchEmE
10-23-2001 11:36 PM
Quick Reply: CASTER PULLING RIGHT..COMMON ISSUES?
