Any guides on changing positive battery cable?
I plan on replacing the corroded terminal. I have a new positive terminal with 2 screw on 8 gauge openings. Can I cut off the corroded wire and just plug in the bare wire into the new connections without issue?
Re: Any guides on changing positive battery cable?
Aslong as it is a real automotive battery terminal you cant go wrong. Just check it for tightness whenever you get the car serviced
