Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
tranny fluid capacity
Old 11-24-2006, 04:17 PM
mrEM1's Avatar
Default tranny fluid capacity
my gf has an 03 AT CIVIC LX COUPE i need to kno how many quarts of atf the car takes as the caR didnt come with an onwers manual. my guess would probably be bout 3-3.5qts or sumthing around that
Old 11-24-2006, 04:26 PM
Miracle's Avatar
Default Re: tranny fluid capacity (mrEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrEM1 &raquo;</TD></TR><TR><TD CLASS="quote"> caR didnt come with an onwers manual. </TD></TR></TABLE>
It would not help... it's not listed in there...
Either call the dealership, of do a drain, filter change, and refill. Then fill it up with a couple quarts, start the car, let it idle, and check the level and fill from there.
Old 11-24-2006, 04:36 PM
mrEM1's Avatar
Default Re: tranny fluid capacity (Miracle)
tranny doesnt have a filter its just drain and fill but i wanna kno how many qts it takes so i can buy the right amount
Old 11-24-2006, 04:37 PM
Miracle's Avatar
Seems like the dealership will be your only hope, unless someone here knows... but most people with an automatic, on this forum, probably haven't done their own fluid changes.
Old 11-24-2006, 04:39 PM
mrEM1's Avatar
well i work as a technician at an infiniti dealership i just dont wanna buy 5 qts and have it just sit around i just wanna buy the right amount
Old 11-25-2006, 07:10 PM
Synapz's Avatar
I DIYed my AT tranny fluid change, and I can say that 3qts is about right.
Old 11-26-2006, 12:43 PM
LowTec MOHawk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrEM1 &raquo;</TD></TR><TR><TD CLASS="quote">my gf has an 03 AT CIVIC LX COUPE i need to kno how many quarts of atf the car takes as the caR didnt come with an onwers manual. my guess would probably be bout 3-3.5qts or sumthing around that</TD></TR></TABLE>
it takes 3 qts. just make sure u check the AT fluid level with the car not running....
Old 11-26-2006, 12:54 PM
Miracle's Avatar
Default Re: tranny fluid capacity (mikeformos03dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeformos03dx &raquo;</TD></TR><TR><TD CLASS="quote">
it takes 3 qts. just make sure u check the AT fluid level with the car not running....</TD></TR></TABLE>
Um, no.
You need to start the car, and let it idle, depress the brake, and manually shift the car throughout the gears to allow the fresh fluid to get into the valve bodies, and inside the shift solenoids.
Old 11-26-2006, 03:23 PM
Synapz's Avatar
I would do the change... drive around, shift thru every gear, then stop and get the fluid level again.
Old 11-26-2006, 11:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miracle &raquo;</TD></TR><TR><TD CLASS="quote">Um, no.
You need to start the car, and let it idle, depress the brake, and manually shift the car throughout the gears to allow the fresh fluid to get into the valve bodies, and inside the shift solenoids.</TD></TR></TABLE>
does that have anything do do with checking the fluid level with the car running or not running?
Old 11-27-2006, 09:39 AM
Synapz's Avatar
The manual sayss (not exact words): Run the car til its warm, after you turn off the car, check fluids quickly under 40 seconds after the car turns off.
And the shifting part after the fluid change is so that you make the best out of the fluid change instead of doing a whole tranny flush. I'm really glad our AT trannies come with a magnetic plug, you can clearly see all of the metal shavings that it catches... but then again, we don't have transmission fluid filters from factory...
oO-SIX-Oo
10
01-27-2010 03:23 PM
roterx7
05-12-2007 03:26 PM
Funnyguy
12-03-2006 07:29 PM
00accordguy
12-09-2005 05:09 AM
1fstgp
03-28-2005 11:16 AM
Quick Reply: tranny fluid capacity
