Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
05 Civic EX Drivers side bulb is out
Old 11-01-2009, 03:02 PM
New User
dabearded1's Avatar
Default 05 Civic EX Drivers side bulb is out
I have owned my 2005 Honda Civic EX since new, and now need to replace the drivers side low beam bulb. I was wondering if there was an easy way to accomplish this without taking a bunch of component off?
Thanks,
DaBearded1
Old 11-01-2009, 04:24 PM
redbull-1's Avatar
Default Re: 05 Civic EX Drivers side bulb is out
It's shown in the owner's manual.
Old 11-01-2009, 04:56 PM
New User
dabearded1's Avatar
Thank you for reinforcing the idea Honda makes it simple. I didn't even consider the owner's manual as a source of real technical information, now I know.
Old 11-04-2009, 12:30 PM
texasnick's Avatar
technically you can change it out without removing that stuff.....but I would recommend just doing it the way Honda says to do it. It's much easier.
Old 11-04-2009, 04:33 PM
New User
dabearded1's Avatar
I got the bulb changed tonight, finally. The windshield wiper fluid filler does not come out like the maual says, but I did manage to get the bulb changed with it in the way.
Old 11-05-2009, 08:19 AM
New User
missgoldie's Avatar
Icon2 Re: Need Help With Headlight Restoration
I've been poking through this site for info on how to change the bulb on my head lights... but it seems people have different things to say.
Does anyone know what the process is specifically for a 2004 si coupe?
Old 11-05-2009, 08:36 AM
Plead da Fif
It Wasn't Me's Avatar
Default Re: Need Help With Headlight Restoration
Refer to post #2
(your post was relocated to this thread. this thread was on page 1 whereas the thread you bumped was over a year old)
Old 11-05-2009, 12:20 PM
New User
missgoldie's Avatar
I see my post was moved here.... Thanks itwasntme
Old 11-06-2009, 12:44 PM
coolusername's Avatar
My passenger side low beam just went out on my 05 also. What the hell. I just picked up some silverstar ultras to replace it though.
Old 11-08-2009, 07:16 AM
New User
missgoldie's Avatar
Icon2 Re: 05 Civic EX Drivers side bulb is out
Okay.... Is there anyone here that has actually successfully CHANGED the low beams? Because I tried yesterday and sure, I can push the tab like nobody's business, but the connector will not MOVE! Are my fingers just weak, or is there something wrong here?
HELP!
Old 11-08-2009, 08:03 AM
redbull-1's Avatar
HELP!
While pushing on the tab, use a flat-head screwdriver to gently push the electrical connector (usually at the edge of the connector) off.
Old 11-08-2009, 08:50 AM
ourbloodykisses's Avatar
those tabs are a pain in the ***, but after you do it a few times its easy. you have to push them together and then pull them to one side or the other, then it will hinge down. twist out the bulb and pull up the hinge and snap in to place.
when doing the tabs, push a little towards the front of the headlight
Old 11-08-2009, 08:55 PM
Spoon ES2's Avatar
it is a pain in the *** when i put my HIDs high and low in had to take out the whole headlight to do them
Old 11-23-2009, 10:42 AM
New User
missgoldie's Avatar
SUCCESS!! Thanks for the advice!
shane 271
25
11-15-2018 10:21 AM
Maverick2291
Honda Civic (2006 - 2015)
04-09-2017 01:21 PM
Shaun Wood
09-26-2015 05:45 PM
slipz214
02-10-2007 02:37 PM
dookieface
02-03-2004 02:26 PM
Quick Reply: 05 Civic EX Drivers side bulb is out
