Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
No compression on cylinders 1 and 4
Old 02-07-2019, 03:32 PM
Khodgins's Avatar
Default No compression on cylinders 1 and 4
Hey there, hope someone can help me out.....I have a 2005 civic 1.7L d17a1....ran great , then all of a sudden one day it had horrible idle ,let it sit ...the next day it started and drove till I hit 3000 rpm then it would bog out....the next day it would crank over but wouldn't fire.... fuel pump was what I changed first, no help....all my coils are getting power sent to them (checked with a test light) .. I changed all the spark plugs and no help... I checked compression and cylinders 1and4 have no compression at all and cylinders 2and3 have 120psi....I was told it wasn't my cam crank sensor cause a mechanic said it was getting an rpm reading with his code reader
HELP ME PLEASE
Old 02-11-2019, 05:25 AM
NDNV's Avatar
Default Re: No compression on cylinders 1 and 4
Head gasket failure?
Old 02-13-2019, 04:04 AM
Khodgins's Avatar
if it was cylinders that were beside each other I'd say head gasket failure but seeing how its 1and 4 I doubt that
Old 02-13-2019, 06:48 AM
night's Avatar
That was some random guess to come to this conclusion :p. And a very strange and suspicious 1 and 4...
But if you have access to air, put the cylinder at tdc then put shop/compressor air directly into the cylinder and listen to where it goes. And top off the radiator and leave the cap off. The water will rise if it's a headgasket.
Old 02-15-2019, 05:51 AM
NDNV's Avatar
Prove me wrong and do the cylinder leakdown test for a failed head gasket. Very common in these engines.
Boostn B20
11
11-27-2008 01:22 PM
dskater4111
08-13-2008 05:17 AM
t3hatch
11-08-2004 09:49 AM
MLogan
05-22-2003 01:09 PM
piscorpio
12
04-28-2003 05:10 AM
Quick Reply: No compression on cylinders 1 and 4
