Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
My Build Thread
Old 11-08-2007, 03:17 AM
blackKready's Avatar
Default K20 into EM2.
my k20 em2 transformation , enjoy.
Modified by blackKready at 3:17 PM 10/17/2008
Old 11-08-2007, 03:18 AM
Default Re: K20 into EM2. (blackKready)
got started tonite , made some good progress. :
whipping out the D , good riddance , lol.
gonzo
dash half out
dash out , lol
cutting a hole from the inside for the RSX wiring harness to enter the cabin , rather the passenger side.
a little tease , little problem , doesnt fit quite perfect , little trimming involved , maybe more , lol , but its going in
story of my life , lol
RSX subframe going on
after power steering line , cables , wiring harness ran in car , blah blah , grabbing the K
finally
not tight or nothing
RSX spindles , brakes , struts , so on. ive retained my civic LCA's , and sway bar.
this is the drivers side cup out of DA style teg , cut away form the chassis , lol. trimmed to rest flush with my chassis when bolted together , fits nice.
cleaning contact points and tacking it in
after half welded in
anyways thats where i stand right now. passenger mount is complete and bolted in and tight. looks great and will do the job fine. more tomorrow guys.
*** YEAH!! , haha. got some more boys. another day done. comming along.
got the dash bolted in tonite , little trimming involved , lol. alot of wiring done. got the drivers side mount fabbed and bolted in. got clutch line made and bled. got front brakes all bled. lots more wiring to do. wiring is pretty much what i have left. shes good to roll.
Old 11-08-2007, 03:19 AM
ill pull it out in the spring for that ****. no time now.
we got er done. i got some issues though , but also right now im running it off the civic ecu , which could be causing the problems idk. heres some pics of the almost end result , lol:
type r cluster came today.
i know its a mess still , lol
you can see here , the rsx harness for the wiper motor , brake fluid/clutch fluid low indicator , and cruise control are seperate from the rest. the civic isnt , so i dug out the rsx harness , got rid of the civic harness , relocated my cruise control under the wiper assembly cover and all comming out a rubber grommet.
ahhhh , done finally , lol , sort of. you can see here i took the sensor , whatever it is , maybe you guys can tell me? out of the bottom of the rsx rad , and fabbed an inline place for it. i figured as long as its in coolant it dont matter. also i reused my civic rad so had to get some plumbing fitting to make a line.
now for the problems , maybe you guys can help. car is running in limp mode. idles very high , never checked for vacuum leaks yet. when you first start the car , the tach works and comes up , than 2 seconds it falls to zero and stays there , i dont get that. the coolant gauge wasnt working , once the car was heated up , i turned it off , turned the key back to on , it came up where its supposed to be , than when you start the car , it falls slowly to the bottom , dont get that either , lol. to add , it doesnt always come up either when you turn key on , got an attitude. car wont rev higher than approx 3500 , hard to tell with no tach. the A/C compressor sounds like a dying animal. engine light is on. with the key in on position , the engine light after being lit solid for a long time , will flash 5 times , than continue staying lit. all i can think of right now , tired. any help would be appreciated guys. thanks.
heres a little vid of it running for the first time:
Old 11-08-2007, 03:30 AM
jivi's Avatar
Wow, nice job done there. well lets wait for the guru's to help you out. Matt is on the way i'm sure.
Old 11-08-2007, 03:37 AM
imroadk1ll's Avatar
well done dude. oh ya one thing u should change ur steering wheel aswell.
Old 11-08-2007, 03:51 AM
Sanji
toyomatt84's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">you can see here i took the sensor , whatever it is , maybe you guys can tell me? out of the bottom of the rsx rad , and fabbed an inline place for it. i figured as long as its in coolant it dont matter. also i reused my civic rad so had to get some plumbing fitting to make a line.</TD></TR></TABLE>
That would be your Fan Switch. It should be in your radiator, since it measures the coolant temperature in the radiator itself, and turns the Fan(s) on accordingly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">now for the problems , maybe you guys can help. car is running in limp mode. idles very high , never checked for vacuum leaks yet. when you first start the car , the tach works and comes up , than 2 seconds it falls to zero and stays there , i dont get that. the coolant gauge wasnt working , once the car was heated up , i turned it off , turned the key back to on , it came up where its supposed to be , than when you start the car , it falls slowly to the bottom , dont get that either , lol. to add , it doesnt always come up either when you turn key on , got an attitude. car wont rev higher than approx 3500 , hard to tell with no tach. the A/C compressor sounds like a dying animal. engine light is on. with the key in on position , the engine light after being lit solid for a long time , will flash 5 times , than continue staying lit. all i can think of right now , tired. any help would be appreciated guys. thanks.</TD></TR></TABLE>
All of those problems (and much more likely, many many more problems) are because of this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">we got er done. i got some issues though , but also right now im running it off the civic ecu , which could be causing the problems idk. heres some pics of the almost end result , lol:</TD></TR></TABLE>
You could very well have destroyed something on your engine. Until you have the proper wiring and ECU for the K, <u>do not attempt to start it again</u>. I can assure you, that you will do severe damage to the engine otherwise.
Other than that, it looks pretty good, and I'd like to see more pictures of your dash.
Old 11-08-2007, 04:08 AM
Default Re: K20 into EM2. (toyomatt84)
ill take some more pics when its aoll cleaned up matt , i love it it looks sweet. as soon as i fond one for a decent price IMROAD , its going on , lol. need a passenger side airbag as well.
matt since you seem to know the K , im still new to the K. hasport as well as 2 other sources told me i could run the civic ecu to get it to honda. i know as well as you , the civic ecu is causing these problems , cause the engine harness is isolated and hasnt been touched so. now i have a question for you matt , a guy on either clubrsx or K20.org told me i could ground a wire off the fuel pump relay , or a wire off the ecu pertaining to fuel pump to bypass immobiliser for now? hes pretty confident in this , says this is how the mugen ecu bypasses it? ever hear of this?
Old 11-08-2007, 04:32 AM
BojeEM2's Avatar
That is alsome dude. I LOVE that you kept the steering wheel, looks great!!!keep up the good work.It is almost time to kick back and drink an Irish Car Bomb
Old 11-08-2007, 04:38 AM
integraa972's Avatar
damn that is nice! good job
why don't you just switch to kpro instead of using the stock ecu
Old 11-08-2007, 04:45 AM
Sanji
toyomatt84's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">ill take some more pics when its aoll cleaned up matt , i love it it looks sweet. as soon as i fond one for a decent price IMROAD , its going on , lol. need a passenger side airbag as well.
matt since you seem to know the K , im still new to the K. hasport as well as 2 other sources told me i could run the civic ecu to get it to honda. i know as well as you , the civic ecu is causing these problems , cause the engine harness is isolated and hasnt been touched so. now i have a question for you matt , a guy on either clubrsx or K20.org told me i could ground a wire off the fuel pump relay , or a wire off the ecu pertaining to fuel pump to bypass immobiliser for now? hes pretty confident in this , says this is how the mugen ecu bypasses it? ever hear of this?</TD></TR></TABLE>
You won't be able to run the Civic's ECU, because it's not wired to take the same sensors that the K-series has. The "Flashing" process only eliminates the Immobilizer. You could re-flash a K-series ECU (preferably one relative to your engine), to match the keys coding, but even then it'll only make sure the car starts. It won't ensure proper engine management.
Now, as for the fuel relay bypass trick, I've heard a bunch of horror stories from people who tried this. If you're only looking to use it for a very short time, it would be ok, but I definitely recommend getting a K-pro, or having your ECU re-flashed, to make sure the Immobilizer is disabled. I do not think there is any ECU solution from Mugen for the K-series, so I wouldn't suggest buying anything under that manufacturer just yet, as it may be someone faking the product name.
Old 11-08-2007, 04:47 AM
Default Re: (integraa972)
cause hondata price gouges and wants 1000 bucks for it. we went from 20 bucks worth of radio shack parts to chip OBD1 ecu , to 1000 bucks? lol. maybe some day , but im not paying 1000 bucks. also looking for a serpentine belt that can eliminate A/C if anyone has info on that. ive read that a 2.4 litre dodge belt will work. CMON MATT , HELP ME OUT , haha.
Old 11-08-2007, 04:50 AM
Sanji
toyomatt84's Avatar
Default Re: (blackKready)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">cause hondata price gouges and wants 1000 bucks for it. we went from 20 bucks worth of radio shack parts to chip OBD1 ecu , to 1000 bucks? lol. maybe some day , but im not paying 1000 bucks. </TD></TR></TABLE>
Either way, you're going to want one, simply from the standpoint of tuning and proper engine management. I wouldn't say it's "Price Gouging" as it's the most versatile Engine Management system I've seen, under $3,500. And, being that it's able to handle nitrous, boost, and an endless amount of other features, it's clearly the best choice for an engine swapped vehicle.
Old 11-08-2007, 06:09 AM
Default Re: (toyomatt84)
horror stories as in? what happened to people who done this? i just want to get it to honda without paying for towing. theres 2 wires comming off the ecu for the immob. one is the signal wire , E27. the other is immobiliser fuel pump. i heard you tap into the immo fuel pump wire and ground it and it runs but the key keeps flashing on the dash.
Old 11-08-2007, 09:52 AM
k20whitevic's Avatar
matt since you seem to know the K , im still new to the K. hasport as well as 2 other sources told me i could run the civic ecu to get it to honda. </TD></TR></TABLE>
I have the biggest ******* problem with this ever! I hate Hasport so much to this day because of the bullshit that they still tell people.
Follow Matt's instructions and you'll be fine.
If you wanted to use and OEM mount, you should have grabbed one from an RSX. It bolts right in, and doesn't look like it was added in. Either way, it looks good.
Old 11-08-2007, 11:11 AM
oddmut's Avatar
Default Re: K20 into EM2. (k20whitevic)
The RSX dash and center console won't work in a 4 dr huh? it will only swap with a 2 dr right?
Old 11-08-2007, 11:26 AM
imroadk1ll's Avatar
Default Re: K20 into EM2. (oddmut)
^^u wanna do that on urs huh?
Old 11-08-2007, 11:29 AM
i had all the mounts off the rsx , they dont bolt in. not even close. not the side mounts i mean.
man i couldnt tell you if it fits a 4dr. theres no info on this. as far as i researched , im the first person to put an rsx dash into an EM2. if someone could prove me wrong , id love to read info on it as well. how they went about it.
im not sure what you mean about the fuel map not being right matt? i was talking to honda , they are programming the keys , not the ecu. the ecu doesnt actually get programmed , they match my keys with it. thats what they told me. also why you can only have one ecu programmed to your car at a time. so i cant see the fuel/ignition map not being good.
Old 11-08-2007, 12:12 PM
oddmut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imroadk1ll &raquo;</TD></TR><TR><TD CLASS="quote">^^u wanna do that on urs huh?</TD></TR></TABLE>
I have to admit, i am very tempted. Also because I like how the RSX head unit faces the driver and not the center. It's more suited for the driver.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">i had all the mounts off the rsx , they dont bolt in. not even close. not the side mounts i mean.
man i couldnt tell you if it fits a 4dr. theres no info on this. as far as i researched , im the first person to put an rsx dash into an EM2. if someone could prove me wrong , id love to read info on it as well. how they went about it.</TD></TR></TABLE>
yes I would be interested. If i had a second car and some money i'd do a project on it and MAKE it work lol. lot of props for the dash man!
Old 11-08-2007, 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready &raquo;</TD></TR><TR><TD CLASS="quote">i had all the mounts off the rsx , they dont bolt in. not even close. not the side mounts i mean.</TD></TR></TABLE>
They do..
Old 11-08-2007, 06:43 PM
heres some finish pics , more of the dash matt.
how i routed power steering , fits mint.
Old 11-08-2007, 08:13 PM
New User
1llmatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
I do not think there is any ECU solution from Mugen for the K-series, so I wouldn't suggest buying anything under that manufacturer just yet, as it may be someone faking the product name.</TD></TR></TABLE>
Mugen N1 ECU [37820-XK5-S0N0]
RSX (2002-2006) 2002-2004 Type S, Type R
I had it in my car for 3 years. It makes decent power but nothing compared to kpro tuned results.
Nice work with the swap! I'm really impressed with the dash.
Old 11-08-2007, 08:34 PM
Sanji
toyomatt84's Avatar
Default Re: K20 into EM2. (1llmatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1llmatic &raquo;</TD></TR><TR><TD CLASS="quote">
Nice work with the swap! I'm really impressed with the dash. </TD></TR></TABLE>
I suppose I should have checked with King Motorsports first, eh?
Anyways, the horror stories I have heard of, are in relation to fuel cutoff as the car is in motion. People have had the fuel pump turn off during driving, and that can cause serious damage to the drivetrain.
PS. I'm really liking the dash, bud. A little more modification and it'll look like it belongs there.
Old 11-09-2007, 03:52 AM
DGAeveryday's Avatar
nice build, looks hella complicated!
Old 11-09-2007, 07:04 AM
k24em2's Avatar
PS. I'm really liking the dash, bud. A little more modification and it'll look like it belongs there. </TD></TR></TABLE>
On a non-turbo car really the only damage that would happen if the fuel pump turned off while driving would be a loss of power...Then the damage would occur as whoever was driving would probably freak out and crash into a post
Quick Reply: My Build Thread
