Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Honda Civic single power door lock not working
Old 06-25-2018, 12:57 PM
bpenner's Avatar
Default Honda Civic single power door lock not working
good day!
I have a 2003 DX-G sedan
My driver’s side rear door power lock is not working.
the lock works fine manually (meaning the mechanism isn’t seized or broken)
i assumed it was the door lock actuator as all of the other door locks were working with the switch and fab.
I just replaced the door lock actuator and nothing!
no power or movement at the actuator
what else can it be if only the one door lock is not working?
Old 06-25-2018, 01:28 PM
thisguyaves's Avatar
Default Re: Honda Civic single power door lock not working
The relay that clicks to send power is likely to blame, and for the life of me I can't remember where it is.
Old 06-25-2018, 03:18 PM
Global Moderator
tech8's Avatar
There is no relay, the door locks are multiplex controlled (i.e., via the multiplex control unit, that is part of the under-dash fuse/relay box).
Old 06-25-2018, 03:23 PM
Global Moderator
tech8's Avatar
The cause may possibly be due to an open (break) in the wires. Gently pull back the rubber grommet boot at the B-Pillar. The Yellow (terminal no. 8) wire and Yel/Blk wire (terminal no. 7) are for the left rear door lock motor.
Old 06-25-2018, 03:53 PM
^this guy. It's been a while.
tapau
04-03-2019 04:00 PM
SubwayH23
08-02-2018 04:09 PM
johnboy1313
13
08-10-2014 01:46 PM
JMod
08-17-2003 05:38 AM
Quick Reply: Honda Civic single power door lock not working
