Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
EM2 Rear disk/replacement
Old 06-19-2018, 07:19 PM
Bert209's Avatar
Default EM2 Rear disk/replacement
Hello everyone, well since it looks like ill be keeping this little sucker ill be doing a rear disk swap, i just got my Rear EL set today and am looking for replacement parts for the front and rears rotors,pads, caliper rebuild, stainless brake lines, but not sure what to go with, anyone whos done this what did you use, Ep3 or Rsx?
Old 06-19-2018, 07:38 PM
Sanji
toyomatt84's Avatar
Default Re: EM2 Rear disk/replacement
There's a thread covering the rear disc swap in the FAQ's thread.
Old 06-20-2018, 06:01 AM
thisguyaves's Avatar
^what toyo said, it's been done a thousand times
But I'll answer your questions anyways.
As far as discs, stay stock unless you have a track ready turbo K20 swap. Ceramic pads will be fine as well. Any parts you get for the rear (assuming you're in the US) make sure they are EP3 2002-2003 parts. Elsewhere in the world, get the EL rear components when buying discs/pads, etc. You shouldn't have to rebuild the calipers, but if you just feel like it then get new bolts and pins from a dealer, grease em good. Make sure you bleed your brakes BLEED YOUR BRAKE (B L E E D Y O U R B R A K E S) when you're done
If you have any specific questions, feel free to come back to this thread and ask away. I've done the swap twice now, both times from an EP3 to an EM2.
Old 06-20-2018, 11:24 AM
Bert209's Avatar
I love all feedback, ive been through the faqs, the one by boilermaker is the one ive followed, but im not looking for giant 6 piston caps, my fault for not being too specific. My issue is replacing componets since its a bit hard( for me at least) to figure out what works. For instance ive confirmed that the front brembo blanks 405 21009 253 are the same for ep3/em2, so front pads are a no brainer. As for front brake lines im looking at stoptech ss 950.40011 but the years covereage and applications are really wide, the 02-06 and 02-05 civic si is 950.40003. So headache begins here and the rear isnt any easier since its hard to confirm if EL rears are the same as Ep3, ive looked at other sites but......... so yeah, ill keep at it but if anyone has done this before feedback is appreciated.
Old 06-20-2018, 01:36 PM
EL rear brake components are the same as pre-face lift EP3. 02-03
Old 06-20-2018, 07:01 PM
Bert209's Avatar
That is what i like to hear so Ep3 rear components work, awesome now i can order everything thaks toyo and yaves
Old 06-20-2018, 08:03 PM
Sanji
toyomatt84's Avatar
Yeah, I don't know where you got the 6 piston idea... but the thread covers a standard EP3/EL/Base DC5 rear disc install, bud.
https://honda-tech.com/forums/honda-...aker1-2054032/
Old 06-20-2018, 11:47 PM
Bert209's Avatar
Yeah six is much lol just want the install to go smooth as possible, it was a beezy installing front control arms even though they came off easy, plus since alot off components are coming from Ebay I dont want to order wrong.
Old 06-21-2018, 05:59 AM
Not to mention, if you're looking into performance stuff, since the EP3 is a typeR or at least an Si, you'll find performance upgrades are a lot more plentiful since it's the sportier civic.
Old 06-21-2018, 11:50 AM
Bert209's Avatar
yeah thats what im looking for, mostly suspension and brake upgrades, i wiil be thinking real hard whether to either upgrade the D17 or Kswap the sucker, im already investing the h22 swap in my accord
Old 06-21-2018, 12:24 PM
As someone who's turboing the D17, I can say a k swap will cost about the same. Bigger up front cost for the K20, trans, drive shafts, ecu, wiring mounts... or put money into the D17 for boost. It'll come to $2k +/- depending on what your goals are.
Old 06-21-2018, 03:38 PM
Sanji
toyomatt84's Avatar
Since the performance ceiling and reliability of the K-series platform supersedes the D17 immensely, it'd be a difficult sell on the D17... unless you don't have the space to use an engine hoist.
Old 06-21-2018, 05:13 PM
^what matt said.
I'm building the D17 because I got the running engine and working trans for $200. So far I'm $1300 into the build with only an ECU and BOV to buy still. it appealed to me because I didn't have to buy new harnesses or mounts, which saved money, on top of the fact that my engine was $600-$900 cheaper than a K20 plus transmission. Plus I can change back to NA quickly if I have problems.
Just have to prioritize.
pinbill
01-15-2018 09:22 AM
NACvicSi
09-05-2009 12:15 PM
eg686
21
04-04-2005 05:07 PM
Solscud007
05-27-2004 07:39 PM
JSTOCK
02-25-2002 08:13 AM
Quick Reply: EM2 Rear disk/replacement
