DIY: Drums ---> Discs Spelled Out (boilermaker1)
#51
Re: DIY: Drums ---> Discs Spelled Out (boilermaker1)
So this is what I need from a 02-03 civic hatch, a rear brake assembly pretty much right?
This includes:
E-brake cable
ABS sensor & wiring (to plug connection by gas tank and in the trunk area by the right rear strut tower)
Knuckle
Hub
Rotor
Caliper
Brake line (to wheel well)
Someone else confirm?
This includes:
E-brake cable
Knuckle
Hub
Rotor
Caliper
#52
Thanks. That comfirms almost everything. OEM Park brake lines will need to be replaced, and looks like the Ex abs covers the proportioning valve,
still curious if anyone has converted to the 4 wheel disc master cylinder, or is the Ex with abs proportioning valve suffiecient?
Also the acura EL OEM base 1.7 dust sheild come without abs holes, does any one know what model will have the dust shields with abs holes that would work for this application?
Thanks. STCYRIOUS
Thanks. STCYRIOUS
#53
Thanks. STCYRIOUS
Thanks. STCYRIOUS
#55
Re: DIY: Drums ---> Discs Spelled Out (theciv)
Do I just need the 4 si brake lines or do I need to replace my steel lines to I have a 2004 ex
99CivicSiBrian
03-15-2007 03:14 AM
